[petsc-users] Important Petsc header files to include
Sat Feb 25 18:05:09 CST 2012
On Sat, Feb 25, 2012 at 18:01, Mengda Wu <wumengda at gmail.com> wrote:
> I am trying to select a set of important petsc header files to included in
> my installation of Petsc. Basically, I would like the header and library
> files to be outside of Petsc source directory. I found there are many
> headers under PETSC_DIR/include. Are these all necessary for a program to
> just use PETSC functions?
It depends which level interface you use (e.g. if you only use KSP, you
wouldn't need the SNES or TS headers). But why do you want to copy these
somewhere? (You're going to have endless problems if you don't know what
you're doing.) It sounds like a waste of time to me.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120225/f94a066e/attachment.htm>
