[petsc-users] testing scalability for ksp/ex22.c (now ex45.c)
Francis Poulin
fpoulin at uwaterloo.ca
Fri Feb 24 14:43:35 CST 2012
Hello,
I wanted to thank everyone for the help and say that I managed to get it running on the cluster and I have done some efficiency calculations. To run the code I used,
mpirun -np # ./ex45 -da_grid_x 5 -da_grid_y 5 -da_grid_z 5 -da_refine 6 -ksp_monitor -pc_type mg -mg_levels_ksp_type richardson -mg_levels_pc_type sor -log_summary
as suggested and found the following
p(#cpu) Tp (parallel) T1 (serial) Efficiency [ = Tp/(p*T1) ]
1 904 904 1.00
2 553 904 0.82
4 274 904 0.83
8 138 904 0.82
16 70 904 0.81
32 36 904 0.78
It seems to scale beautifully starting at 2 but there is a big drop from 1 to 2. I suspect there's a very good reason for this, I just don't know what.
Thanks again for all of your help,
Francis
On 2012-02-24, at 12:59 PM, Jed Brown wrote:
> On Fri, Feb 24, 2012 at 11:49, Francis Poulin <fpoulin at uwaterloo.ca> wrote:
> I don't seem to have the hydra in my bin folder but I do have petscmpiexec that I've been using.
> That's just the name of my mpiexec. Use whichever one is used with your build of PETSc.
>> Use these, it will run the same method and sizes as the options I gave for ex22 before.
>> mpiexec.hydra -n 2 ./ex45 -da_grid_x 5 -da_grid_y 5 -da_grid_z 5 -da_refine 5 -ksp_monitor -pc_type mg -mg_levels_ksp_type richardson -mg_levels_pc_type sor -log_summary
> Also, I want to install PetSc on an SGI machine that I have access to. I have been told that using MPT would give better performance compared to mpich2. When I configure petsc on this server I don't suppose
> -with-mpi-dir=/opt/sgi/mpt
> the above would work because of the different name. Do you have a suggestion as to what I could try?
> It's just the way you launch parallel jobs.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120224/61d74b39/attachment.htm>
