[petsc-users] Accessing Vector's ghost values
Bojan Niceno
bojan.niceno at psi.ch
Thu Feb 23 15:16:48 CST 2012
Dear Jed,
thanks.
Now I have the following:
- Array unk, which should hold values inside the partition and in ghost
cells. It is big enough to hold both
- Vec x, created by command VecCreateGhost, with proper padding for
ghost cells
- Successful call to linear solver in parallel.
But I need to copy ghost values from x to my array unk.
How can I do it?
Kind regards,
Bojan
On 2/23/2012 10:10 PM, Jed Brown wrote:
> On Thu, Feb 23, 2012 at 15:05, Bojan Niceno <bojan.niceno at psi.ch
> <mailto:bojan.niceno at psi.ch>> wrote:
> No, I use global.
> The local form is just a local vector. It doesn't even know that a
> global problem exists. You can't index into it using global indices.
> (In general, there is no efficient way to look up information in the
> local vector (includes ghost points) using global indices.)
> for(Int i=0; i<n; i++) {
> Int gi = mesh.nodes[i].global_number;
> VecGetValues(x, 1, &gi, &unk[i]);
> "n" is defined as the number of cells inside, i.e. without
> buffers. "unk" is my external array. If I try to access buffer
> values, I use:
> for(Int i=0; i<N; i++) {
> But then I end up with tons of warnings, presumably because I am
> going beyond "n". Vector x was created with VecCreateGhost.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120223/4f275bfa/attachment.htm>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120223/4f275bfa/attachment.png>
