[petsc-users] Accessing Vector's ghost values
Bojan Niceno bojan.niceno at psi.ch
Thu Feb 23 14:43:52 CST 2012
Dear Matt,
I have a new insight, although is not the full resolution.  If I change
my code in PETScSolver.cpp from:
   |  Make necessary PETSc intializations for vetors  |
   Int   nghost = N - n;
   Int * ghosts = new Int(nghost);
   for(Int n=0; n<M.mesh.nodes.size(); n++) {
     assert( M.mesh.nodes[n].global_number >= 0);
     assert( M.mesh.nodes[n].global_number < 14065);
   for(Int i=n; i<N; i++) {
     assert( M.mesh.nodes[i].global_number >= 0);
     assert( M.mesh.nodes[i].global_number < 14065);
     assert( ! (M.mesh.nodes[i].global_number >= n_start &&
                M.mesh.nodes[i].global_number <  n_end) );
       ghosts[i] = M.mesh.nodes[i].global_number;
   VecCreateGhost(PETSC_COMM_WORLD, n, PETSC_DECIDE, nghost, &ghosts[0],
&x);
to:
   Int     nghost = N - n;
   Indices ghosts;                                         // <---= NEW!
       ghosts.push_back( M.mesh.nodes[i].global_number );  // <---= NEW!
   assert( ghosts.size() == nghost ); // <---= NEW!
&x);
I pass the VecCreateGhost phase.  "Indices" is an STL container of
integers.  It seems it works better than classical C array for this case.
However, I still do not see the ghost values, i.e. I get the following
error:
[1]PETSC ERROR: --------------------- Error Message
[1]PETSC ERROR: [0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Argument out of range!
[0]PETSC ERROR: Can only get local values, trying 3529!
[0]PETSC ERROR:
[1]PETSC ERROR: Can only get local values, trying 22!
[1]PETSC ERROR:
[1]PETSC ERROR: Petsc Release Version 3.2.0, Patch 6, Wed Jan 11
09:28:45 CST 2012
[1]PETSC ERROR: See docs/changes/index.html for recent updates.
[1]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[1]PETSC ERROR: See docs/index.html for manual pages.
[1]PETSC ERROR: [2]PETSC ERROR: --------------------- Error Message
[2]PETSC ERROR: Argument out of range!
[2]PETSC ERROR: Can only get local values, trying 86!
[2]PETSC ERROR:
[2]PETSC ERROR: Petsc Release Version 3.2.0, Patch 6, Wed Jan 11
09:28:45 CST 2012
when I am trying to access values in ghost cells.  What do I have to use
to see them ghosts?  I reckon VecGhostGetLocalForm should be used, right?
     Kind regards,
     Bojan
On 2/23/2012 8:36 PM, Matthew Knepley wrote:
> On Thu, Feb 23, 2012 at 1:33 PM, Bojan Niceno <bojan.niceno at psi.ch
> <mailto:bojan.niceno at psi.ch>> wrote:
>     Dear Matt,
>     I sent the code as an attached tarball.  I sent it with case I
>     run, so is 2 MB big.  It is now in the cue for moderator's approval.
> No, you HAVE to send it to petsc-maint at mcs.anl.gov
> <mailto:petsc-maint at mcs.anl.gov>, as I said last time, for exactly
> this reason.
>   Matt
>     Thanks.
>         Kind regards,
>         Bojan
>     On 2/23/2012 8:04 PM, Matthew Knepley wrote:
>>     On Thu, Feb 23, 2012 at 12:51 PM, Bojan Niceno
>>     <bojan.niceno at psi.ch <mailto:bojan.niceno at psi.ch>> wrote:
>>         Dear Matt,
>>         are you sure?  It is almost 4000 lines long!  Shall I send
>>         only the function which bother me?
>>         If the entire code is what you need, shall I make a tarball
>>         and attach it?
>>     Send something the builds and runs. Don't care how long it is.
>>        Matt
>>             Kind regards,
>>             Bojan
>>         On 2/23/2012 7:44 PM, Matthew Knepley wrote:
>>>         On Thu, Feb 23, 2012 at 12:28 PM, Bojan Niceno
>>>             On 2/23/2012 7:24 PM, Matthew Knepley wrote:
>>>>             On Thu, Feb 23, 2012 at 12:05 PM, Bojan Niceno
>>>>                 Dear Matthew,
>>>>                 thank you for your response.  When I use
>>>>                 VecCreateGhost, I get the following:
>>>>             It appears that you passed a bad communicator. Did you
>>>>             not initialize a 'comm' variable?
>>>             I pass PETSC_COMM_WORLD to VecCreateGhost.
>>>             I don't know what you mean by 'comm' variable :-(  I
>>>             called all the routines to initialize PETSc.
>>>         Send your code to petsc-maint at mcs.anl.gov
>>>         <mailto:petsc-maint at mcs.anl.gov>.
>>>            Matt
>>>                 Cheers,
>>>                 Bojan
>>>>                Matt
>>>>                 [0]PETSC ERROR:
>>>>                 [0]PETSC ERROR: Caught signal number 11 SEGV:
>>>>                 Segmentation Violation, probably memory access out
>>>>                 of range
>>>>                 [0]PETSC ERROR: Try option -start_in_debugger or
>>>>                 -on_error_attach_debugger
>>>>                 [0]PETSC ERROR: or see
>>>>                 http://www.mcs.anl.gov/petsc/petsc-as/documentation/faq.html#valgrind[0]PETSC
>>>>                 ERROR: or try http://valgrind.org on GNU/linux and
>>>>                 Apple Mac OS X to find memory corruption errors
>>>>                 [0]PETSC ERROR: likely location of problem given in
>>>>                 stack below
>>>>                 [0]PETSC ERROR: ---------------------  Stack Frames
>>>>                 [0]PETSC ERROR: Note: The EXACT line numbers in the
>>>>                 stack are not available,
>>>>                 [0]PETSC ERROR:       INSTEAD the line number of
>>>>                 the start of the function
>>>>                 [0]PETSC ERROR:       is given.
>>>>                 [0]PETSC ERROR: [0] PetscCommDuplicate line 140
>>>>                 src/sys/objects/tagm.c
>>>>                 [0]PETSC ERROR: [0] PetscHeaderCreate_Private line
>>>>                 30 src/sys/objects/inherit.c
>>>>                 [0]PETSC ERROR: [0] VecCreate line 32
>>>>                 src/vec/vec/interface/veccreate.c
>>>>                 [0]PETSC ERROR: [0] VecCreateGhostWithArray line
>>>>                 567 src/vec/vec/impls/mpi/pbvec.c
>>>>                 [0]PETSC ERROR: [0] VecCreateGhost line 647
>>>>                 [0]PETSC ERROR: Signal received!
>>>>                 [0]PETSC ERROR:
>>>>                 [0]PETSC ERROR: Petsc Release Version 3.2.0, Patch
>>>>                 6, Wed Jan 11 09:28:45 CST 2012
>>>>                 [0]PETSC ERROR: See docs/changes/index.html for
>>>>                 recent updates.
>>>>                 [0]PETSC ERROR: See docs/faq.html for hints about
>>>>                 trouble shooting.
>>>>                 [0]PETSC ERROR: See docs/index.html for manual pages.
>>>>                 [0]PETSC ERROR:
>>>>                 [0]PETSC ERROR: ./PSI-Flow on a arch-linu named
>>>>                 lccfd06 by niceno Thu Feb 23 19:02:45 2012
>>>>                 [0]PETSC ERROR: Libraries linked from
>>>>                 /homecfd/niceno/PETSc-3.2-p6/arch-linux2-c-debug/lib
>>>>                 [0]PETSC ERROR: Configure run at Fri Feb 10
>>>>                 10:24:13 2012
>>>>                 [0]PETSC ERROR: Configure options
>>>>                 [0]PETSC ERROR:
>>>>                 [0]PETSC ERROR: User provided function() line 0 in
>>>>                 unknown directory unknown file
>>>>                 I don't understand what could be causing it.  I
>>>>                 took very good care to match the global numbers of
>>>>                 ghost cells when calling VecCreateGhost
>>>>                     Kind regards,
>>>>                     Bojan
>>>>                 On 2/23/2012 5:53 PM, Matthew Knepley wrote:
>>>>>                 On Thu, Feb 23, 2012 at 10:46 AM, Bojan Niceno
>>>>>                 wrote:
>>>>>                     Hi all,
>>>>>                     I've never used a mailing list before, so I
>>>>>                     hope this message will reach PETSc users and
>>>>>                     experts and someone might be willing to help
>>>>>                     me.  I am also novice in PETSc.
>>>>>                     I have developed an unstructured finite volume
>>>>>                     solver on top of PETSc libraries.  In
>>>>>                     sequential, it works like a charm.  For the
>>>>>                     parallel version, I do domain decomposition
>>>>>                     externally with Metis, and work out local and
>>>>>                     global numberings, as well as communication
>>>>>                     patterns between processor.  (The latter don't
>>>>>                     seem to be needed for PETSc, though.)  When I
>>>>>                     run my program in parallel, it also works, but
>>>>>                     I miss values in vectors' ghost points.
>>>>>                     I create vectors with command:
>>>>>                     VecCreate(PETSC_COMM_WORLD, &x);
>>>>>                     Is it possible to get the ghost values if a
>>>>>                     vector is created like this?
>>>>>                 I do not understand this question. By definition,
>>>>>                 "ghost values" are those not stored in the global
>>>>>                 vector.
>>>>>                     I have tried to use VecCreateGhost, but for
>>>>>                     some reason which is beyond my comprehension,
>>>>>                     PETSc goes berserk when it reaches the
>>>>>                     command: VecCreateGhost(PETSC_COMM_WORLD, n,
>>>>>                     PETSC_DECIDE, nghost, ifrom, &x)
>>>>>                 I think you can understand that "berserk" tells me
>>>>>                 absolutely nothing. Error message? Stack trace?
>>>>>                 Did you try to run an
>>>>>                 example which uses VecGhost?
>>>>>                   Thanks,
>>>>>                      Matt
>>>>>                     Can anyone help me?  Either how to reach ghost
>>>>>                     values for vector created by VecCreate, or how
>>>>>                     to use VecCreateGhost properly?
>>>>>                       Kind regards,
>>>>>                       Bojan
>>>>>                 What most experimenters take for granted before
>>>>>                 they begin their experiments is infinitely more
>>>>>                 interesting than any results to which their
>>>>>                 experiments lead.
>>>>>                 -- Norbert Wiener
>>>>             What most experimenters take for granted before they
>>>>             begin their experiments is infinitely more interesting
>>>>             than any results to which their experiments lead.
>>>>             -- Norbert Wiener
>>>         What most experimenters take for granted before they begin
>>>         their experiments is infinitely more interesting than any
>>>         -- Norbert Wiener
>>     What most experimenters take for granted before they begin their
>>     experiments is infinitely more interesting than any results to
>>     -- Norbert Wiener
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120223/62f77a4b/attachment-0001.htm>
Name: not available
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120223/62f77a4b/attachment-0005.png>
Name: not available
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120223/62f77a4b/attachment-0006.png>
Name: not available
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120223/62f77a4b/attachment-0007.png>
Name: not available
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120223/62f77a4b/attachment-0008.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120223/62f77a4b/attachment-0009.png>
