[petsc-users] Accessing Vector's ghost values
Bojan Niceno
bojan.niceno at psi.ch
Thu Feb 23 12:28:31 CST 2012
On 2/23/2012 7:22 PM, Max Rudolph wrote:
> Did you try running with -on_error_attach_debugger and and using your
> debugger to try to figure out where your code is segfaulting?
Well, it's a bit embarrassing, but I should admit that I never use
debuggers. I use "exit(0)" to find the place where program breaks. It
breaks at the very call to VecCreateGhost.
Kind regards,
Bojan
