[petsc-users] Accessing Vector's ghost values
Bojan Niceno bojan.niceno at psi.ch
Thu Feb 23 12:28:10 CST 2012
On 2/23/2012 7:24 PM, Matthew Knepley wrote:
> On Thu, Feb 23, 2012 at 12:05 PM, Bojan Niceno <bojan.niceno at psi.ch
> <mailto:bojan.niceno at psi.ch>> wrote:
>     Dear Matthew,
>     thank you for your response.  When I use VecCreateGhost, I get the
>     following:
> It appears that you passed a bad communicator. Did you not initialize
> a 'comm' variable?
I pass PETSC_COMM_WORLD to VecCreateGhost.
I don't know what you mean by 'comm' variable :-(  I called all the
routines to initialize PETSc.
     Cheers,
     Bojan
>    Matt
>     [0]PETSC ERROR:
>     [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation
>     Violation, probably memory access out of range
>     [0]PETSC ERROR: Try option -start_in_debugger or
>     -on_error_attach_debugger
>     [0]PETSC ERROR: or see
>     http://www.mcs.anl.gov/petsc/petsc-as/documentation/faq.html#valgrind[0]PETSC
>     ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X
>     to find memory corruption errors
>     [0]PETSC ERROR: likely location of problem given in stack below
>     [0]PETSC ERROR: ---------------------  Stack Frames
>     [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not
>     available,
>     [0]PETSC ERROR:       INSTEAD the line number of the start of the
>     function
>     [0]PETSC ERROR:       is given.
>     [0]PETSC ERROR: [0] PetscCommDuplicate line 140 src/sys/objects/tagm.c
>     [0]PETSC ERROR: [0] PetscHeaderCreate_Private line 30
>     src/sys/objects/inherit.c
>     [0]PETSC ERROR: [0] VecCreate line 32
>     src/vec/vec/interface/veccreate.c
>     [0]PETSC ERROR: [0] VecCreateGhostWithArray line 567
>     src/vec/vec/impls/mpi/pbvec.c
>     [0]PETSC ERROR: [0] VecCreateGhost line 647
>     [0]PETSC ERROR: --------------------- Error Message
>     [0]PETSC ERROR: Signal received!
>     [0]PETSC ERROR:
>     [0]PETSC ERROR: Petsc Release Version 3.2.0, Patch 6, Wed Jan 11
>     09:28:45 CST 2012
>     [0]PETSC ERROR: See docs/changes/index.html for recent updates.
>     [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>     [0]PETSC ERROR: See docs/index.html for manual pages.
>     [0]PETSC ERROR:
>     [0]PETSC ERROR: ./PSI-Flow on a arch-linu named lccfd06 by niceno
>     Thu Feb 23 19:02:45 2012
>     [0]PETSC ERROR: Libraries linked from
>     /homecfd/niceno/PETSc-3.2-p6/arch-linux2-c-debug/lib
>     [0]PETSC ERROR: Configure run at Fri Feb 10 10:24:13 2012
>     [0]PETSC ERROR: Configure options
>     [0]PETSC ERROR:
>     [0]PETSC ERROR: User provided function() line 0 in unknown
>     directory unknown file
>     I don't understand what could be causing it.  I took very good
>     care to match the global numbers of ghost cells when calling
>     VecCreateGhost
>         Kind regards,
>         Bojan
>     On 2/23/2012 5:53 PM, Matthew Knepley wrote:
>>     On Thu, Feb 23, 2012 at 10:46 AM, Bojan Niceno
>>     <bojan.niceno at psi.ch <mailto:bojan.niceno at psi.ch>> wrote:
>>         Hi all,
>>         I've never used a mailing list before, so I hope this message
>>         will reach PETSc users and experts and someone might be
>>         willing to help me.  I am also novice in PETSc.
>>         I have developed an unstructured finite volume solver on top
>>         of PETSc libraries.  In sequential, it works like a charm.
>>          For the parallel version, I do domain decomposition
>>         externally with Metis, and work out local and global
>>         numberings, as well as communication patterns between
>>         processor.  (The latter don't seem to be needed for PETSc,
>>         though.)  When I run my program in parallel, it also works,
>>         but I miss values in vectors' ghost points.
>>         I create vectors with command: VecCreate(PETSC_COMM_WORLD, &x);
>>         Is it possible to get the ghost values if a vector is created
>>         like this?
>>     I do not understand this question. By definition, "ghost values"
>>     are those not stored in the global vector.
>>         I have tried to use VecCreateGhost, but for some reason which
>>         is beyond my comprehension, PETSc goes berserk when it
>>         reaches the command: VecCreateGhost(PETSC_COMM_WORLD, n,
>>         PETSC_DECIDE, nghost, ifrom, &x)
>>     I think you can understand that "berserk" tells me absolutely
>>     nothing. Error message? Stack trace? Did you try to run an
>>     example which uses VecGhost?
>>       Thanks,
>>          Matt
>>         Can anyone help me?  Either how to reach ghost values for
>>         vector created by VecCreate, or how to use VecCreateGhost
>>         properly?
>>           Kind regards,
>>           Bojan
>>     What most experimenters take for granted before they begin their
>>     experiments is infinitely more interesting than any results to
>>     which their experiments lead.
>>     -- Norbert Wiener
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120223/cfc35dd2/attachment.htm>
Name: not available
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120223/cfc35dd2/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120223/cfc35dd2/attachment-0001.png>
