[petsc-users] Accessing Vector's ghost values
Bojan Niceno
bojan.niceno at psi.ch
Thu Feb 23 12:05:26 CST 2012
Dear Matthew,
thank you for your response. When I use VecCreateGhost, I get the
following:
[0]PETSC ERROR:
[0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
probably memory access out of range
[0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[0]PETSC ERROR: or see
http://www.mcs.anl.gov/petsc/petsc-as/documentation/faq.html#valgrind[0]PETSC
ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to
find memory corruption errors
[0]PETSC ERROR: likely location of problem given in stack below
[0]PETSC ERROR: --------------------- Stack Frames
[0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[0]PETSC ERROR: INSTEAD the line number of the start of the function
[0]PETSC ERROR: is given.
[0]PETSC ERROR: [0] PetscCommDuplicate line 140 src/sys/objects/tagm.c
[0]PETSC ERROR: [0] PetscHeaderCreate_Private line 30
src/sys/objects/inherit.c
[0]PETSC ERROR: [0] VecCreate line 32 src/vec/vec/interface/veccreate.c
[0]PETSC ERROR: [0] VecCreateGhostWithArray line 567
src/vec/vec/impls/mpi/pbvec.c
[0]PETSC ERROR: [0] VecCreateGhost line 647 src/vec/vec/impls/mpi/pbvec.c
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Signal received!
[0]PETSC ERROR:
[0]PETSC ERROR: Petsc Release Version 3.2.0, Patch 6, Wed Jan 11
09:28:45 CST 2012
[0]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
[0]PETSC ERROR:
[0]PETSC ERROR: ./PSI-Flow on a arch-linu named lccfd06 by niceno Thu
Feb 23 19:02:45 2012
[0]PETSC ERROR: Libraries linked from
/homecfd/niceno/PETSc-3.2-p6/arch-linux2-c-debug/lib
[0]PETSC ERROR: Configure run at Fri Feb 10 10:24:13 2012
[0]PETSC ERROR: Configure options
[0]PETSC ERROR:
[0]PETSC ERROR: User provided function() line 0 in unknown directory
unknown file
I don't understand what could be causing it. I took very good care to
match the global numbers of ghost cells when calling VecCreateGhost
Kind regards,
Bojan
On 2/23/2012 5:53 PM, Matthew Knepley wrote:
> On Thu, Feb 23, 2012 at 10:46 AM, Bojan Niceno <bojan.niceno at psi.ch
> <mailto:bojan.niceno at psi.ch>> wrote:
> Hi all,
> I've never used a mailing list before, so I hope this message will
> reach PETSc users and experts and someone might be willing to help
> me. I am also novice in PETSc.
> I have developed an unstructured finite volume solver on top of
> PETSc libraries. In sequential, it works like a charm. For the
> parallel version, I do domain decomposition externally with Metis,
> and work out local and global numberings, as well as communication
> patterns between processor. (The latter don't seem to be needed
> for PETSc, though.) When I run my program in parallel, it also
> works, but I miss values in vectors' ghost points.
> I create vectors with command: VecCreate(PETSC_COMM_WORLD, &x);
> Is it possible to get the ghost values if a vector is created like
> this?
> I do not understand this question. By definition, "ghost values" are
> those not stored in the global vector.
> I have tried to use VecCreateGhost, but for some reason which is
> beyond my comprehension, PETSc goes berserk when it reaches the
> command: VecCreateGhost(PETSC_COMM_WORLD, n, PETSC_DECIDE, nghost,
> ifrom, &x)
> I think you can understand that "berserk" tells me absolutely nothing.
> Error message? Stack trace? Did you try to run an
> example which uses VecGhost?
> Thanks,
> Matt
> Can anyone help me? Either how to reach ghost values for vector
> created by VecCreate, or how to use VecCreateGhost properly?
> Kind regards,
> Bojan
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120223/5d9156d3/attachment.htm>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120223/5d9156d3/attachment.png>
