[petsc-users] AO
Mohammad Mirzadeh mirzadeh at gmail.com
Wed Feb 22 16:52:58 CST 2012
Should I be worried about function call overhead if make calls like
AOXXXXToYYYY(ao, 1, &node) for each node when setting up the linear system?
If so, is there an array where AO internally saves the mapping information
that I can access or do I need to first save the mapping once and reuse it?
Mohammad
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120222/e98e595e/attachment.htm>
