[petsc-users] MatStructure flag in KSPSetOperators
Kuhlemann, Verena
vkuhlem at emory.edu
Wed Feb 22 08:52:38 CST 2012
I am not sure that I understand the MatStructure flag in the call of KSPSetOperators
correctly.
If I use KSPSetOperators(ksp, A, P, DIFFERENT_NONZERO_PATTERN) and then
solve two linear systems with the same matrix operators but different rhs is
the preconditioner reassembled in every solve. I.e., if I call
KSPSolve(ksp,b1,x1);
KSPSolve(ksp,b2,x2);
And if I use KSPSetOperators(ksp, A, P, SAME_PRECONDITIONER) the preconditioner is
only setup one time and reused later.
Or is the flag only important if I change the matrix operators in between.
Thank you,
Verena
This e-mail message (including any attachments) is for the sole use of
the intended recipient(s) and may contain confidential and privileged
information. If the reader of this message is not the intended
recipient, you are hereby notified that any dissemination, distribution
or copying of this message (including any attachments) is strictly
prohibited.
If you have received this message in error, please contact
the sender by reply e-mail message and destroy all copies of the
original message (including attachments).
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120222/4009b5f2/attachment.htm>
