[petsc-users] check for NULL pointer in VecCreateGhost
Mohammad Mirzadeh
mirzadeh at gmail.com
Tue Feb 21 13:08:05 CST 2012
Thanks Matt. If that is not against PETSc coding policies, it sounds
reasonable to me.
Mohammad
On Mon, Feb 20, 2012 at 7:30 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Feb 20, 2012 at 6:30 PM, Mohammad Mirzadeh <mirzadeh at gmail.com>wrote:
>> Matt, I'm just trying to understand what is going on and why the things
>> do what they do -- I'm not asking for anything in particular :). I just
>> thought that the situation for VecCreateGhost and AOXXXXToYYYY are somewhat
>> similar here and was surprised to see one crashes on NULL while the other
>> one does not.
>> I have included a check on the pointer and size for AO calls and just
>> wanted to check if I need the same thing with VecCreateGhost if there is
>> such an internal check.
> I have no problem making that change. It is pushed to petsc-dev.
> Matt
>> Mohammad
>> On Mon, Feb 20, 2012 at 4:10 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>> On Mon, Feb 20, 2012 at 5:58 PM, Mohammad Mirzadeh <mirzadeh at gmail.com>wrote:
>>>> Just if wondering what the actual code is, here's the bit causing the
>>>> trouble:
>>>> AOApplicationToPetsc(ao, ghostNodes.size(), (int*)ghostNodes);
>>>> VecCreateGhost(comm, localNodes.size(), PETSC_DECIDE,
>>>> ghostNodes.size(), (int*)ghostNodes, &v);
>>>> AOPetscToApplication(ao, ghostNodes.size(), (int*)ghostNodes);
>>>> when the code is in serial, ghostNodes.size() = 0 and (int*)ghostNodes
>>>> = NULL.
>>> So you are asking us to give up checking for NULL if the size is 0?
>>> Matt
>>>> On Mon, Feb 20, 2012 at 3:54 PM, Mohammad Mirzadeh <mirzadeh at gmail.com>wrote:
>>>>> Sure, Jed. My bad. Here's the whole message when the code is run in
>>>>> _serial_:
>>>>> [0]PETSC ERROR: --------------------- Error Message
>>>>> [0]PETSC ERROR: Invalid pointer!
>>>>> [0]PETSC ERROR: Null Pointer: Parameter # 3!
>>>>> [0]PETSC ERROR:
>>>>> [0]PETSC ERROR: Petsc Release Version 3.2.0, Patch 6, Wed Jan 11
>>>>> 09:28:45 CST 2012
>>>>> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
>>>>> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>>>>> [0]PETSC ERROR: See docs/index.html for manual pages.
>>>>> [0]PETSC ERROR:
>>>>> [0]PETSC ERROR: ./petsc on a arch-linu named mohammad-laptop by
>>>>> mohammad Mon Feb 20 15:52:25 2012
>>>>> [0]PETSC ERROR: Libraries linked from
>>>>> /home/mohammad/soft/petsc-3.2-p6/arch-linux2-cxx-debug/lib
>>>>> [0]PETSC ERROR: Configure run at Thu Feb 16 02:16:40 2012
>>>>> [0]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++
>>>>> --with-fc=gfortran --with-clanguage=cxx --download-f-blas-lapack=1
>>>>> --download-mpich=1 --download-hypre=1 --download-ml=1
>>>>> --with-parmetis-include=/home/mohammad/soft/parmetis/include
>>>>> --with-parmetis-lib="-L/home/mohammad/soft/parmetis/lib -lparmetis -lmetis"
>>>>> --download-superlu_dist=1
>>>>> [0]PETSC ERROR:
>>>>> [0]PETSC ERROR: AOApplicationToPetsc() line 249 in
>>>>> /home/mohammad/soft/petsc-3.2-p6/src/dm/ao/interface/ao.c
>>>>> [0]PETSC ERROR:
>>>>> 09:28:45 CST 2012
>>>>> [0]PETSC ERROR:
>>>>> [0]PETSC ERROR:
>>>>> [0]PETSC ERROR: AOPetscToApplication() line 210 in
>>>>> It seems to complain about the 3rd parameter of AOApplicationToPetsc()
>>>>> and AOPetscToApplication(). VecCreateGhost, on the other hand, is fine.
>>>>> On Mon, Feb 20, 2012 at 3:47 PM, Jed Brown <jedbrown at mcs.anl.gov>wrote:
>>>>>> On Mon, Feb 20, 2012 at 17:25, Mohammad Mirzadeh <mirzadeh at gmail.com>wrote:
>>>>>>> Hi,
>>>>>>> Is there an internal check to see if the 'ghost' pointer in
>>>>>>> VecCreateGhost() is NULL ? This can happen, for example, if the code is run
>>>>>>> in serial and the there are no ghost points (hence n_ghost = 0 and ghost =
>>>>>>> NULL(implementation dependent of course) ). AOXXXXToYYYY functions seem to
>>>>>>> crash if the corresponding pointer is NULL.
>>>>>> Always send the whole error message.
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120221/4aed5ea2/attachment.htm>
