[petsc-users] convergence problem in spherical coordinates
Mon Feb 20 17:37:29 CST 2012
On Mon, Feb 20, 2012 at 4:52 PM, Patrick Alken
<patrick.alken at colorado.edu>wrote:
>  Hello all,
>   I am having great difficulty solving a 3D finite difference equation in
> spherical coordinates. I am solving the equation in a spherical shell
> region S(a,b), with the boundary conditions being that the function is 0 on
> both boundaries (r = a and r = b). I haven't imposed any boundary
> conditions on theta or phi which may be a reason its not converging. The
> phi boundary condition would be that the function is periodic in phi, but I
> don't know if this needs to be put into the matrix somehow?
1) The periodicity appears in the definition of the FD derivative in phi.
Since this is Cartesian, you can use a DA in 3D, and make one
direction periodic.
2) Don't you have a coordinate singularity at the pole? This is why every
code I know of uses something like a Ying-Yang grid.
   Matt
> I nondimensionalized the equation before solving which helped a little
> bit. I've also scaled the matrix and RHS vectors by their maximum element
> to make all entries <= 1.
> I've tried both direct and iterative solvers. The direct solvers give a
> fairly accurate solution for small grids but seem unstable for larger
> grids. The PETSc iterative solvers converge for very small grids but for
> medium to large grids don't converge at all.
> When running with the command (for a small grid):
> *> ./main -ksp_converged_reason -ksp_monitor_true_residual -pc_type svd
> -pc_svd_monitor*
> I get the output:
>     SVD: condition number 5.929088512946e+03, 0 of 1440 singular values
> are (nearly) zero
>     SVD: smallest singular values: 2.742809162118e-04 2.807446554985e-04
> 1.548488288425e-03 1.852332719983e-03 2.782708934678e-03
>     SVD: largest singular values : 1.590835571953e+00 1.593368145758e+00
> 1.595771695877e+00 1.623691828398e+00 1.626235829632e+00
>   0 KSP preconditioned resid norm 2.154365616645e+03 true resid norm
> 8.365589263063e+00 ||r(i)||/||b|| 1.000000000000e+00
>   1 KSP preconditioned resid norm 4.832753933427e-10 true resid norm
> 4.587845792963e-12 ||r(i)||/||b|| 5.484187244549e-13
> Linear solve converged due to CONVERGED_RTOL iterations 1
> When plotting the output of this SVD solution, it looks pretty good, but
> svd isn't practical for larger grids.
> Using the command (on the same grid):
> -ksp_compute_eigenvalues -ksp_gmres_restart 1000 -pc_type none*
> The output is attached. There do not appear to be any 0 eigenvalues. The
> solution here is much less accurate than the SVD case since it didn't
> converge.
> I've also tried the -ksp_diagonal_scale -ksp_diagonal_scale_fix options
> which don't help very much.
> Any advice on how to trouble shoot this would be greatly appreciated.
> Some things I've checked already:
> 1) there aren't any 0 rows in the matrix
> 2) using direct solvers on very small grids seems to give decent solutions
> 3) there don't appear to be any 0 singular values or eigenvalues
> Perhaps the matrix has a null space, but I don't know how I would find out
> what the null space is? Is there a tutorial on how to do this?
> Thanks in advance!
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120220/96872b58/attachment.htm>
