El 16/02/2012, a las 17:16, Verena Kuhlemann escribió: > Thanks for the answer. > > When I want to set a preconditioner then I will need to do that via STGetKSP and the KSPGetPC ? > In the end I want to use a shell preconditioner. Yes, you can do that. Jose
