[petsc-users] Ghost point communication for Red-Black Gauss-Siedel
Matthew Knepley
knepley at gmail.com
Wed Feb 15 20:55:44 CST 2012
On Wed, Feb 15, 2012 at 8:53 PM, Sylvain Barbot <sylbar.vainbot at gmail.com>wrote:
> Hi Matt,
> You're right, I'm not worried about the interior points, that why I'm
> looking for updating the ghost points only - the interior points
> unaffected by the process. Jed seems to indicate that it's not a
> bottle neck.
> Jed,
> Would you recommend a particular step to improve cache performance?
> Can you be a bit more specific?
R-B has crappy cache performance since you alternately pull data but ignore
half of it. Why not just use the GMG in PETSc? Its very flexible, scalable,
and efficient.
Matt
> Sylvain
> 2012/2/15 Matthew Knepley <knepley at gmail.com>:
> > On Wed, Feb 15, 2012 at 5:25 PM, Sylvain Barbot <
> > wrote:
> >> Hi All,
> >> I'm implementing an elasticity multi-grid solver with Petsc with
> >> matrix shells. I am using the Red-Black Gauss-Siedel smoother. In the
> >> middle of the Red-Black passes, I need to update the ghost points
> >> between processors. To do that effectively, I'd like to update only
> >> the ghost points between the different processors, instead of the
> >> whole array. The goal is to do the most possible operations in place
> > What does that mean? Updating ghost dofs means taking the value of that
> > dof on the process that owns it, and copying it to all the processes
> which
> > hold
> > that as a ghost dof. This operation has no meaning for interior points.
> > Matt
> >> in local array lx, and having to update global vector x only once. The
> >> working matrix multiply smoothing operation is shown below. I'm using
> >> Petsc 3.1. I read about
> http://www.mcs.anl.gov/petsc/petsc-3.1/docs/manualpages/Vec/VecGhostUpdateBegin.html
> >> but I'm not entirely clear whether this does what I want or not.
> >> SUBROUTINE matrixsmooth(A,b,omega,flag,shift,its,level,x,ierr)
> >> USE types
> >> USE heap
> >> USE petscsys
> >> USE petscda
> >> USE petscis
> >> USE petscvec
> >> USE petscmat
> >> USE petscpc
> >> USE petscksp
> >> IMPLICIT NONE
> >> Mat, INTENT(IN) :: A
> >> Vec, INTENT(IN) :: b
> >> Vec, INTENT(INOUT) :: x
> >> PetscReal, INTENT(IN) :: omega,shift
> >> MatSORType, INTENT(IN) :: flag
> >> PetscInt, INTENT(IN) :: its, level ! iterations, multi-grid level
> >> PetscErrorCode, INTENT(OUT) :: ierr
> >> Vec :: lx,lb
> >> PetscInt :: istart,iend
> >> PetscScalar, POINTER :: px(:) ! pointer to solution array
> >> PetscScalar, POINTER :: pb(:) ! pointer to body-force array
> >> INTEGER :: rank,isize,i,k
> >> INTEGER :: sw,off,p
> >> INTEGER :: i2,i3,i2i,i3i, &
> >> i000,i0p0,i00p, &
> >> i0m0,i00m
> >> TYPE(DALOCALINFOF90) :: info
> >> CALL MPI_COMM_RANK(PETSC_COMM_WORLD,rank,ierr)
> >> CALL MPI_COMM_SIZE(PETSC_COMM_WORLD,isize,ierr)
> >> CALL VecGetOwnershipRange(x,istart,iend,ierr)
> >> ! allocate memory for local vector with ghost points
> >> CALL DACreateLocalVector(c%daul(1+level),lx,ierr)
> >> CALL VecDuplicate(lx,lb,ierr)
> >> ! retrieve forcing term b with ghost points
> >> CALL DAGlobalToLocalBegin(c%daul(1+level),b,INSERT_VALUES,lb,ierr)
> >> CALL DAGlobalToLocalEnd(c%daul(1+level),b,INSERT_VALUES,lb,ierr)
> >> ! obtain a pointer to local data
> >> CALL VecGetArrayF90(lx,px,ierr);
> >> CALL VecGetArrayF90(lb,pb,ierr);
> >> ! geometry info about local vector and padding
> >> CALL DAGetLocalInfoF90(c%daul(1+level),info,ierr);
> >> ! retrieve stencil width (ghost-point padding)
> >> CALL
> DAGetInfo(c%daul(1+level),PETSC_NULL_INTEGER,PETSC_NULL_INTEGER, &
> PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,
> >> sw,PETSC_NULL_INTEGER, &
> >> PETSC_NULL_INTEGER,ierr);
> >> ! offset due to node topology
> >> off=MOD(info%xm+info%ym,2)
> >> ! fast smoothing (relaxation) its=number of iteration
> >> DO k=1,its
> >> ! Red-Black Gauss-Siedel scheme
> >> DO p=0,1
> >> ! retrieve initial guess x with ghost points
> >> CALL
> >> DAGlobalToLocalBegin(c%daul(1+level),x,INSERT_VALUES,lx,ierr)
> >> CALL
> DAGlobalToLocalEnd(c%daul(1+level),x,INSERT_VALUES,lx,ierr)
> >> ! smoothing (relaxation)
> >> DO i=istart+p+off,iend-1,info%dof*2
> >> i3=(i-istart)/(info%xm*info%dof)
> >> i2=(i-istart-i3*info%xm*info%dof)/info%dof
> >> i3=i3+i3i ! i3 in ( 0 .. sx3-1 )
> >> i2=i2+i2i ! i2 in ( 0 .. sx2-1 )
> >> i000=1+((sw+i3-i3i+0)*(info%xm+2*sw)+sw+i2-i2i+0)*info%dof
> >> i0p0=1+((sw+i3-i3i+0)*(info%xm+2*sw)+sw+i2-i2i+1)*info%dof
> >> i00p=1+((sw+i3-i3i+1)*(info%xm+2*sw)+sw+i2-i2i+0)*info%dof
> >> i0m0=1+((sw+i3-i3i+0)*(info%xm+2*sw)+sw+i2-i2i-1)*info%dof
> >> i00m=1+((sw+i3-i3i-1)*(info%xm+2*sw)+sw+i2-i2i+0)*info%dof
> >> px(i000+IU1)=px(i000+IU1)+ &
> >> (pb(i000+IU1)-((+(px(i0p0+IU1)-px(i000+IU1)
> >> )-(px(i000+IU1)-px(i0m0+IU1) )) &
> >> +(+(px(i00p+IU1)-px(i000+IU1) )-(px(i000+IU1)-px(i00m+IU1) )))) /
> >> (-4._8)
> >> END DO
> >> ! publish new values of x for its global vector
> >> CALL DALocalToGlobal(c%daul(1+level),lx,INSERT_VALUES,x,ierr)
> >> END DO
> >> END DO
> >> ! dispose of the local vectors
> >> CALL VecRestoreArrayF90(lx,px,ierr)
> >> CALL VecRestoreArrayF90(lb,pb,ierr)
> >> CALL DARestoreLocalVector(c%daul(1+level),lx,ierr)
> >> CALL DARestoreLocalVector(c%daul(1+level),lb,ierr)
> >> END SUBROUTINE matrixsmooth
> >> Could this be changed to something like:
> >> ... INITIALIZE...
> >> CALL DAGlobalToLocalBegin(c%daul(1+c%level),x,INSERT_VALUES,lx,ierr)
> >> CALL DAGlobalToLocalEnd(c%daul(1+c%level),x,INSERT_VALUES,lx,ierr)
> >> DO k=1,its
> >> DO p=0,1
> >> ...STENCIL OPERATION...
> >> END DO
> >> ...UPDATE GHOST POINTS...
> >> END DO
> >> END DO
> >> ...CLEAN MEMORY...
> >> Any recommendation?
> >> Best wishes,
> >> Sylvain Barbot
> > What most experimenters take for granted before they begin their
> experiments
> > is infinitely more interesting than any results to which their
> experiments
> > lead.
> > -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120215/d2d48463/attachment.htm>
