[petsc-users] Null space of discrete Laplace with periodic boundary conditions
Mohammad Mirzadeh mirzadeh at gmail.com
Tue Feb 14 16:47:25 CST 2012
What do you set on the sphere? If you impose a Dirichlet  BC that makes it
nonsingular
Mohammad
On Feb 14, 2012 7:27 AM, "Jed Brown" <jedbrown at mcs.anl.gov> wrote:
> On Tue, Feb 14, 2012 at 09:20, Thomas Witkowski <
> thomas.witkowski at tu-dresden.de> wrote:
>> I discretize the Laplace operator (using finite element) on the unit
>> square equipped with periodic boundary conditions on all four edges. Is it
>> correct that the null space is still constant? I wounder, because when I
>> run the same code on a sphere (so a 2D surface embedded in 3D), the
>> resulting matrix is non-singular. I thought, that both cases should be
>> somehow equal with respect to the null space?
> The continuum operators for both cases have a constant null space, so if
> either is nonsingular in your finite element code, it's a discretization
> problem.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120214/8898efcb/attachment.htm>
