[petsc-users] MatSetValues() for MATMPICUSP
Fri Feb 10 23:30:20 CST 2012
On Fri, Feb 10, 2012 at 11:10 PM, recrusader <recrusader at gmail.com> wrote:
> Dear Matt,
> I added the print codes in libmesh after creating the matrix as follows:
>     "    ierr = MatCreateMPIAIJ (libMesh::COMM_WORLD,
>                                 m_local, n_local,
>                                 m_global, n_global,
>                                 PETSC_NULL, (int*) &n_nz[0],
>                                 PETSC_NULL, (int*) &n_oz[0], &_mat);
>              CHKERRABORT(libMesh::COMM_WORLD,ierr);
>       MatSetOption(_mat,MAT_NEW_NONZERO_ALLOCATION_ERR,PETSC_FALSE); //by
> Yujie
>       std::cout<<"MatSetOption"<<std::endl;"
> I run the same codes in CPU and GPU modes (the same parameters except that
> GPU uses '-vec_type mpicusp -mat_type mpiaijcusp'). I can find
> "MatSetOption" output from both the modes. Does that mean that the codes
> set the options for both the modes?
> Thank you very much.
Yes, so you should have no problem with allocation errors. Partial reports
like this help no one. It would be
somewhat helpful to include a stack trace, to verify that after this change
you see an error. If might actually
enable us to find your error if you sent a small test code which failed.
     Matt
> Best,
> Yujie
> On Fri, Feb 10, 2012 at 3:14 PM, Matthew Knepley <knepley at gmail.com>wrote:
>> On Fri, Feb 10, 2012 at 3:12 PM, recrusader <recrusader at gmail.com> wrote:
>>> Dear Jed,
>>> The first example works. However, the example uses MatSetValuesStencil()
>>> not MatSetValues(). Are they same?
>> MatSetValuesStencil() calls MatSetValues(). I suspect that your MPIAIJ
>> matrix does not have the option set to
>> throw an error when inserting a new nonzero, and your MPICUSP matrix does.
>>    Matt
>>> Thanks a lot,
>>> Yujie
>>> On Fri, Feb 10, 2012 at 2:51 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>>>> On Fri, Feb 10, 2012 at 14:49, recrusader <recrusader at gmail.com> wrote:
>>>>> Since MATMPIAIJ works (I didn't change anything. Just set the vec and
>>>>> mat types to mpicusp and mpiaijcusp for GPU), I think the problem is likely
>>>>> from MatSetValues_MPIAIJ().
>>>>> Which PETSc examples can test this function?
>>>> Try src/ksp/ksp/examples/tutorials/ex43.c and
>>>> src/snes/examples/tutorials/ex48.c
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120210/916aa4a5/attachment.htm>
