[petsc-users] MatSetValues() for MATMPICUSP
Fri Feb 10 15:14:15 CST 2012
On Fri, Feb 10, 2012 at 3:12 PM, recrusader <recrusader at gmail.com> wrote:
> Dear Jed,
> The first example works. However, the example uses MatSetValuesStencil()
> not MatSetValues(). Are they same?
MatSetValuesStencil() calls MatSetValues(). I suspect that your MPIAIJ
matrix does not have the option set to
throw an error when inserting a new nonzero, and your MPICUSP matrix does.
   Matt
> Thanks a lot,
> Yujie
> On Fri, Feb 10, 2012 at 2:51 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>> On Fri, Feb 10, 2012 at 14:49, recrusader <recrusader at gmail.com> wrote:
>>> Since MATMPIAIJ works (I didn't change anything. Just set the vec and
>>> mat types to mpicusp and mpiaijcusp for GPU), I think the problem is likely
>>> from MatSetValues_MPIAIJ().
>>> Which PETSc examples can test this function?
>> Try src/ksp/ksp/examples/tutorials/ex43.c and
>> src/snes/examples/tutorials/ex48.c
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120210/7de7782e/attachment-0001.htm>
