[petsc-users] Hang at PetscLayoutSetUp()
Dmitry Karpeev karpeev at mcs.anl.gov
Tue Feb 7 21:17:00 CST 2012
Since the processor count is down, can you run it with debugging and see
what the arguments to PetscLayout are?
Dmitry
On Tue, Feb 7, 2012 at 9:00 PM, Derek Gaston <friedmud at gmail.com> wrote:
> On Tue, Feb 7, 2012 at 7:56 PM, Matthew Knepley <knepley at gmail.com> wrote:
>> Same question: are you sure every process is there. I will bet $10 there
>>  is at least one missing.
> Ok - I'll get that info - I tried to compile PADB a moment ago... but it
> didn't compile.  It configured just fine... but compile is a no-go.  It
> doesn't look like too bad of an error, but I don't have time to fix it now
> so I'll just script something up with GDB.  At least I got the processor
> count down for this job so it won't be too much data to sort through.
> Derek
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120207/1c6f584d/attachment.htm>
