[petsc-users] one compilation error in PETSc-dev with enabling GPU and complex number
recrusader
recrusader at gmail.com
Tue Feb 7 11:15:59 CST 2012
The following is the reply from Thrust developers,
"The issue here is that the member functions of std::complex are not
decorated with __host__ __device__ and therefore the compiler complains
when asked to instantiate such functions in other __host__ __device__ code.
If you switch std::complex to cusp::complex (which *is* decorated with
__host__ __device__) then the problem should disappear."
Thanks.
On Tue, Feb 7, 2012 at 11:13 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Feb 7, 2012 at 10:19 AM, recrusader <recrusader at gmail.com> wrote:
>> Dear Matt,
>> I got the help from Thrust developers.
>> The problem is
>> in PETSc, we define CUSPARRAY using cusp::array1d<PetscScalar,
>> cusp::device_memory>. Generaly, PetscScalar is std::complex.
>> However, the CUSPARRAY array cannot be decorated at GPU side. We need
>> cusp::array1d<cusp::complex, cusp::device_memory>.
>> Is there any simple method to process this in PETSc?
> This reply does not make any sense to me. What do you mean by the word
> "decorated"? If you mean that they only support the
> complex type cusp::complex, then I advise you to configure for real
> numbers. We do not support cusp::complex as our complex
> type.
> Thanks,
> Matt
>> Thank you very much.
>> Best,
>> Yujie
>> On Sun, Jan 29, 2012 at 1:20 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>> On Sun, Jan 29, 2012 at 1:05 PM, recrusader <recrusader at gmail.com>wrote:
>>>> Thank you very much, Matt,
>>>> You mean the headers of the simple codes, I further simply the codes as
>>> This is a question for the CUSP mailing list.
>>> Thanks,
>>> Matt
>>>> #include <cusp/blas.h>
>>>> #include <cusp/array1d.h>
>>>> int main(void)
>>>> cusp::array1d<std::complex<double>, cusp::host_memory> *x;
>>>> x=new cusp::array1d<std::complex<double>, cusp::host_memory>(2,0.0);
>>>> std::complex<double> alpha(1,2.0);
>>>> cusp::blas::scal(*x,alpha);
>>>> return 0;
>>>> I got the same compilation results "
>>>> login1$ nvcc gputest.cu -o gputest
>>>> /opt/apps/cuda/4.0/cuda/bin/../include/cusp/detail/blas.inl(134):
>>>> warning: calling a __host__ function from a __host__ __device__
>>>> function is not allowed
>>>> detected during:
>>>> instantiation of "void
>>>> cusp::blas::detail::SCAL<T>::operator()(T2 &) [with
>>>> T=std::complex<double>, T2=std::complex<double>]"
>>>> /opt/apps/cuda/4.0/cuda/bin/../include/thrust/detail/host/for_each.inl(37):
>>>> here
>>>> instantiation of "InputIterator
>>>> thrust::detail::host::for_each(InputIterator, InputIterator,
>>>> UnaryFunction) [with
>>>> InputIterator=thrust::detail::normal_iterator<std::complex<double> *>,
>>>> UnaryFunction=cusp::blas::detail::SCAL<std::complex<double>>]"
>>>> /opt/apps/cuda/4.0/cuda/bin/../include/thrust/detail/dispatch/for_each.h(46):
>>>> here
>>>> thrust::detail::dispatch::for_each(InputIterator, InputIterator,
>>>> UnaryFunction, thrust::host_space_tag) [with
>>>> /opt/apps/cuda/4.0/cuda/bin/../include/thrust/detail/for_each.inl(51):
>>>> here
>>>> thrust::detail::for_each(InputIterator, InputIterator, UnaryFunction)
>>>> [with InputIterator=thrust::detail::normal_iterator<std::complex<double>
>>>> *>, UnaryFunction=cusp::blas::detail::SCAL<std::complex<double>>]"
>>>> /opt/apps/cuda/4.0/cuda/bin/../include/thrust/detail/for_each.inl(67):
>>>> here
>>>> instantiation of "void thrust::for_each(InputIterator,
>>>> InputIterator, UnaryFunction) [with
>>>> (367): here
>>>> cusp::blas::detail::scal(ForwardIterator, ForwardIterator, ScalarType)
>>>> [with
>>>> ForwardIterator=thrust::detail::normal_iterator<std::complex<double>
>>>> *>, ScalarType=std::complex<double>]"
>>>> (748): here
>>>> instantiation of "void cusp::blas::scal(Array &,
>>>> ScalarType) [with Array=cusp::array1d<std::complex<double>,
>>>> cusp::host_memory>, ScalarType=std::complex<double>]"
>>>> gputest.cu(25): here
>>>> Thanks a lot.
>>>> Best,
>>>> Yujie
>>>> On 1/29/12, Matthew Knepley <knepley at gmail.com> wrote:
>>>> > On Sun, Jan 29, 2012 at 12:53 PM, recrusader <recrusader at gmail.com>
>>>> wrote:
>>>> >> Dear PETSc developers,
>>>> >> With your help, I can successfully PETSc-deve with enabling GPU and
>>>> >> complex number.
>>>> >> However, when I compiled the codes, I met some errors. I also tried
>>>> to
>>>> >> use simple codes to realize the same function. However, the errors
>>>> >> disappear. One example is as follows:
>>>> >> for the function "VecScale_SeqCUSP"
>>>> >> "#undef __FUNCT__
>>>> >> #define __FUNCT__ "VecScale_SeqCUSP"
>>>> >> PetscErrorCode VecScale_SeqCUSP(Vec xin, PetscScalar alpha)
>>>> >> CUSPARRAY *xarray;
>>>> >> PetscErrorCode ierr;
>>>> >> PetscFunctionBegin;
>>>> >> if (alpha == 0.0) {
>>>> >> ierr = VecSet_SeqCUSP(xin,alpha);CHKERRQ(ierr);
>>>> >> } else if (alpha != 1.0) {
>>>> >> ierr = VecCUSPGetArrayReadWrite(xin,&xarray);CHKERRQ(ierr);
>>>> >> try {
>>>> >> cusp::blas::scal(*xarray,alpha);
>>>> >> } catch(char* ex) {
>>>> >> SETERRQ1(PETSC_COMM_SELF,PETSC_ERR_LIB,"CUSP error: %s", ex);
>>>> >> ierr = VecCUSPRestoreArrayReadWrite(xin,&xarray);CHKERRQ(ierr);
>>>> >> ierr = WaitForGPU();CHKERRCUSP(ierr);
>>>> >> ierr = PetscLogFlops(xin->map->n);CHKERRQ(ierr);
>>>> >> PetscFunctionReturn(0);
>>>> >> When I compiled PETSc-dev, I met the following errors:
>>>> >> " /opt/apps/cuda/4.0/cuda/include/cusp/detail/blas.inl(134): warning:
>>>> >> calling a __host__ function from a __host__ __device__ function is
>>>> not
>>>> >> allowed
>>>> >> detected during:
>>>> >> T=std::complex<double>, T2=PetscScalar]"
>>>> /opt/apps/cuda/4.0/cuda/include/thrust/detail/device/cuda/for_each.inl(72):
>>>> >> here
>>>> thrust::detail::device::cuda::for_each_n_closure<RandomAccessIterator,
>>>> >> Size, UnaryFunction>::operator()() [with
>>>> RandomAccessIterator=thrust::detail::normal_iterator<thrust::device_ptr<PetscScalar>>,
>>>> >> Size=long,
>>>> /opt/apps/cuda/4.0/cuda/include/thrust/detail/device/cuda/detail/launch_closure.inl(51):
>>>> >> here
>>>> thrust::detail::device::cuda::detail::launch_closure_by_value(NullaryFunction)
>>>> >> [with
>>>> NullaryFunction=thrust::detail::device::cuda::for_each_n_closure<thrust::detail::normal_iterator<thrust::device_ptr<PetscScalar>>,
>>>> >> long, cusp::blas::detail::SCAL<std::complex<double>>>]"
>>>> /opt/apps/cuda/4.0/cuda/include/thrust/detail/device/cuda/detail/launch_closure.inl(71):
>>>> >> here
>>>> >> instantiation of "size_t
>>>> thrust::detail::device::cuda::detail::closure_launcher_base<NullaryFunction,
>>>> >> launch_by_value>::block_size_with_maximal_occupancy(size_t) [with
>>>> >> long, cusp::blas::detail::SCAL<std::complex<double>>>,
>>>> >> launch_by_value=true]"
>>>> /opt/apps/cuda/4.0/cuda/include/thrust/detail/device/cuda/detail/launch_closure.inl(136):
>>>> >> here
>>>> >> instantiation of "thrust::pair<size_t, size_t>
>>>> thrust::detail::device::cuda::detail::closure_launcher<NullaryFunction>::configuration_with_maximal_occupancy(Size)
>>>> >> [with
>>>> >> long, cusp::blas::detail::SCAL<std::complex<double>>>, Size=long]"
>>>> /opt/apps/cuda/4.0/cuda/include/thrust/detail/device/cuda/detail/launch_closure.inl(145):
>>>> >> here
>>>> >> [ 6 instantiation contexts not shown ]
>>>> >> UnaryFunction, thrust::device_space_tag) [with
>>>> InputIterator=thrust::detail::normal_iterator<thrust::device_ptr<PetscScalar>>,
>>>> >> /opt/apps/cuda/4.0/cuda/include/thrust/detail/for_each.inl(51): here
>>>> >> [with
>>>> >> /opt/apps/cuda/4.0/cuda/include/thrust/detail/for_each.inl(67): here
>>>> >> (367): here
>>>> ScalarType)
>>>> >> [with
>>>> ForwardIterator=thrust::detail::normal_iterator<thrust::device_ptr<PetscScalar>>,
>>>> >> (748): here
>>>> >> ScalarType) [with Array=cusp::array1d<PetscScalar,
>>>> >> cusp::device_memory>, ScalarType=std::complex<double>]"
>>>> >> veccusp.cu(1185): here
>>>> >> error: a value of type "int" cannot be assigned to an entity of type
>>>> >> "_ZNSt7complexIdE9_ComplexTE"
>>>> >> However, I further realize simiar codes as
>>>> >> #include <thrust/version.h>
>>>> >> #include <cusp/version.h>
>>>> >> #include <iostream>
>>>> >> #include <complex>
>>>> >> int main(void)
>>>> >> return 0;
>>>> >> When I complied it using "nvcc gputest.cu -o gputest", I only meet
>>>> >> warning information as follows:
>>>> >> detected during:
>>>> >> here
>>>> >> here
>>>> >> here
>>>> >> [with
>>>> >> here
>>>> >> (367): here
>>>> ScalarType)
>>>> >> [with
>>>> >> (748): here
>>>> >> There are not errors like
>>>> "/opt/apps/cuda/4.0/cuda/include/thrust/detail/device/cuda/detail/launch_closure.inl(51):
>>>> >> "_ZNSt7complexIdE9_ComplexTE" "
>>>> >> Furthermore, the warning information is also different between
>>>> >> PETSc-dev and simple codes.
>>>> >> Could you give me some suggestion for this errors? Thank you very
>>>> much.
>>>> > The headers are complicated to get right. The whole point of what we
>>>> did is
>>>> > to give a way to use GPU
>>>> > simply through the existing PETSc linear algebra interface.
>>>> > Matt
>>>> >> Best,
>>>> >> Yujie
>>>> > What most experimenters take for granted before they begin their
>>>> > experiments is infinitely more interesting than any results to which
>>>> their
>>>> > experiments lead.
>>>> > -- Norbert Wiener
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120207/704a52db/attachment-0001.htm>
