[petsc-users] Use boomeramg to solve system of PDEs
Fri Feb 3 06:43:34 CST 2012
On Fri, Feb 3, 2012 at 15:34, Thomas Witkowski <
thomas.witkowski at tu-dresden.de> wrote:
> I did it, but gmres with boomeramg diverges. The system has three unknowns
> per mesh node. Each block operator is either a Laplace or the mass matrix.
> So each block by-itself is solvable with amg. Thus it follows that the
> overall system is solvable? In my case the system is not symmetric and
> indefinite. The boundary conditions are Neuman everywhere, but the global
> matrix has an empty null space. As the local blocks (in the case of the
> discrete Laplace) have constant null space I set -pc_hypre_boomeramg_relax_
> **type_coarse Jacobi for boomeramg not to make direct solves on coarse
> grid. Is there any theoretical reason that AMG cannot work in this case or
> is it a question of just the right settings for the solver?
How did you order dofs?
How are the blocks coupled?
AMG is more delicate and generally less robust for systems.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120203/6a167d8a/attachment.htm>
