[petsc-users] Valgrind and uninitialized values
    Max Rudolph
    rudolph at berkeley.edu
    Thu Feb  2 23:42:48 CST 2012
No, I am using the version of Petsc supplied on the lonestar machine, which was compiled with their MPI build. I will look into making a suppressions file. Thanks for your help.
Max
>  I am trying to track down a memory corruption bug using valgrind, but I am
>  having to wade through lots and lots of error messages similar to this one,
>  which I believe are either spurious or related to some problem in Petsc and
>  not in my code (please correct me if I'm wrong!)
> Are you using ---download-mpich? It should be valgrind clean. These are a
> pain, but you can make a supressions
> file as well.
>    Matt
