[petsc-users] pctype hmpi
Fri Aug 31 13:31:33 CDT 2012
On Aug 31, 2012, at 1:27 PM, George Pau <gpau at lbl.gov> wrote:
> Hi Barry,
> 1. It is the exact same error related to MPI_ERR_COMM and MPI_Bcast.
   That should not happen. Please run and send all the output including the exact command line used
>  I am currently using the MPICH2 distribution provided by ubuntu but if MPICH version that Petsc download with -download-mpich works, I can use that.
> 2. If I use hmpi_merge_size, I will need to launch mpiexec with more than 1 cpus.  But, petsc will complain that the pctype hmpi can only be used in serial.
   That should not happen. Run with 2 MPI processes and -hmpi_merge_size 2  and send the complete error message.
  Barry
> George
> On Aug 31, 2012, at 11:17 AM, Barry Smith wrote:
>> On Aug 30, 2012, at 10:02 PM, George Pau <gpau at lbl.gov> wrote:
>>> Hi Barry,
>>> I tried with the addition of
>>> -hmpi_spawn_size 3
>>> but I am still getting the same error though.
>>   The EXACT same error? Or some other error?
>>    What happens if you run with the -hmpi_merge_size <size> option instead?
>>  Barry
>> 1) I am getting a crash with the spawn version I suspect is due to bugs in the MPICH version I am using related to spawn.
>> 2) I am getting errors with the merge version due to Apple's ASLR which they make hard to turn off.
>>> I am using mpich2.  Any other options to try?
>>> George
>>> On Aug 30, 2012, at 7:28 PM, Barry Smith wrote:
>>>> On Aug 30, 2012, at 7:24 PM, George Pau <gpau at lbl.gov> wrote:
>>>>> Hi,
>>>>> I have some issues using the -pctype hmpi.  I used the same setting found at
>>>>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCHMPI.html
>>>>> i.e.
>>>>> -pc_type hmpi
>>>>> -ksp_type preonly
>>>>> -hmpi_ksp_type cg
>>>>> -hmpi_pc_type hypre
>>>>> -hmpi_pc_hypre_type boomeramg
>>>>> My command  is
>>>>> mpiexec -n 1 myprogram
>>>> Sorry the documentation doesn't make this clearer. You need to start PETSc with special options to get the "worker" processes initialized. From the manual page for PCHMPI it has
>>>> See PetscHMPIMerge() and PetscHMPISpawn() for two ways to start up MPI for use with this preconditioner
>>>> This will tell you want option to start PETSc up with.
>>>> I will fix the PC so that it prints a far more useful error message.
>>>> Barry
>>>>> But, I get
>>>>> [gilbert:4041] *** An error occurred in MPI_Bcast
>>>>> [gilbert:4041] *** on communicator MPI_COMM_WORLD
>>>>> [gilbert:4041] *** MPI_ERR_COMM: invalid communicator
>>>>> [gilbert:4041] *** MPI_ERRORS_ARE_FATAL (your MPI job will now abort)
>>>>> with openmpi.  I get similar error with mpich2
>>>>> Fatal error in PMPI_Bcast: Invalid communicator, error stack:
>>>>> PMPI_Bcast(1478): MPI_Bcast(buf=0x7fffb683479c, count=1, MPI_INT, root=0, comm=0x0) failed
>>>>> PMPI_Bcast(1418): Invalid communicator
>>>>> I couldn't figure out what is wrong.    My petsc is  version 3.3.3 and the configuration is -with-debugging=0 --with-mpi-dir=/usr/lib/openmpi --download-hypre=1 and I am on a Ubuntu machine.
>>>>> Note that with the default pc_type and ksp_type, everything is fine.  It was also tested with multiple processors.  I wondering whether there are some options that I am not specifying correctly?
>>>>> George Pau
>>>>> Earth Sciences Division
>>>>> Lawrence Berkeley National Laboratory
>>>>> One Cyclotron, MS 74-120
>>>>> Berkeley, CA 94720
>>>>> (510) 486-7196
>>>>> gpau at lbl.gov
>>>>> http://esd.lbl.gov/about/staff/georgepau/
