[petsc-users] pctype hmpi
George Pau
gpau at lbl.gov
Thu Aug 30 22:02:49 CDT 2012
Hi Barry,
I tried with the addition of
-hmpi_spawn_size 3
but I am still getting the same error though. I am using mpich2. Any other options to try?
George
On Aug 30, 2012, at 7:28 PM, Barry Smith wrote:
> On Aug 30, 2012, at 7:24 PM, George Pau <gpau at lbl.gov> wrote:
>> Hi,
>> I have some issues using the -pctype hmpi. I used the same setting found at
>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCHMPI.html
>> i.e.
>> -pc_type hmpi
>> -ksp_type preonly
>> -hmpi_ksp_type cg
>> -hmpi_pc_type hypre
>> -hmpi_pc_hypre_type boomeramg
>> My command is
>> mpiexec -n 1 myprogram
> Sorry the documentation doesn't make this clearer. You need to start PETSc with special options to get the "worker" processes initialized. From the manual page for PCHMPI it has
> See PetscHMPIMerge() and PetscHMPISpawn() for two ways to start up MPI for use with this preconditioner
> This will tell you want option to start PETSc up with.
> I will fix the PC so that it prints a far more useful error message.
> Barry
>> But, I get
>> [gilbert:4041] *** An error occurred in MPI_Bcast
>> [gilbert:4041] *** on communicator MPI_COMM_WORLD
>> [gilbert:4041] *** MPI_ERR_COMM: invalid communicator
>> [gilbert:4041] *** MPI_ERRORS_ARE_FATAL (your MPI job will now abort)
>> with openmpi. I get similar error with mpich2
>> Fatal error in PMPI_Bcast: Invalid communicator, error stack:
>> PMPI_Bcast(1478): MPI_Bcast(buf=0x7fffb683479c, count=1, MPI_INT, root=0, comm=0x0) failed
>> PMPI_Bcast(1418): Invalid communicator
>> I couldn't figure out what is wrong. My petsc is version 3.3.3 and the configuration is -with-debugging=0 --with-mpi-dir=/usr/lib/openmpi --download-hypre=1 and I am on a Ubuntu machine.
>> Note that with the default pc_type and ksp_type, everything is fine. It was also tested with multiple processors. I wondering whether there are some options that I am not specifying correctly?
>> George Pau
>> Earth Sciences Division
>> Lawrence Berkeley National Laboratory
>> One Cyclotron, MS 74-120
>> Berkeley, CA 94720
>> (510) 486-7196
>> gpau at lbl.gov
>> http://esd.lbl.gov/about/staff/georgepau/
