[petsc-users] pctype hmpi
George Pau
gpau at lbl.gov
Thu Aug 30 19:24:02 CDT 2012
I have some issues using the -pctype hmpi. I used the same setting found
at
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCHMPI.html
i.e.
-pc_type hmpi
-ksp_type preonly
-hmpi_ksp_type cg
-hmpi_pc_type hypre
-hmpi_pc_hypre_type boomeramg
My command is
mpiexec -n 1 myprogram
But, I get
[gilbert:4041] *** An error occurred in MPI_Bcast
[gilbert:4041] *** on communicator MPI_COMM_WORLD
[gilbert:4041] *** MPI_ERR_COMM: invalid communicator
[gilbert:4041] *** MPI_ERRORS_ARE_FATAL (your MPI job will now abort)
with openmpi. I get similar error with mpich2
Fatal error in PMPI_Bcast: Invalid communicator, error stack:
PMPI_Bcast(1478): MPI_Bcast(buf=0x7fffb683479c, count=1, MPI_INT, root=0,
comm=0x0) failed
PMPI_Bcast(1418): Invalid communicator
I couldn't figure out what is wrong. My petsc is version 3.3.3 and the
configuration is -with-debugging=0 --with-mpi-dir=/usr/lib/openmpi
--download-hypre=1 and I am on a Ubuntu machine.
Note that with the default pc_type and ksp_type, everything is fine. It
was also tested with multiple processors. I wondering whether there are
some options that I am not specifying correctly?
George Pau
Earth Sciences Division
Lawrence Berkeley National Laboratory
One Cyclotron, MS 74-120
Berkeley, CA 94720
(510) 486-7196
gpau at lbl.gov
http://esd.lbl.gov/about/staff/georgepau/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120830/8a862d4b/attachment.html>
