[petsc-users] Recompile PETSc after small changes
Wed Aug 29 06:46:32 CDT 2012
To elaborate, if you have CMake on your machine, PETSc's configure will
make it be used by default when you type "make". Those makefiles have
dependencies written into them (unlike PETSc's legacy makefiles in the
source tree) so recompilation after a small change should take about two
seconds to compile that one file and link.
On Wed, Aug 29, 2012 at 2:03 AM, Aron Ahmadia <aron.ahmadia at kaust.edu.sa>wrote:
> The CMake-generated Makefiles.
> A
> Sent from my iPhone
> On Aug 29, 2012, at 6:56 AM, Thomas Witkowski <
> thomas.witkowski at tu-dresden.de> wrote:
> > What's the most efficient way to recompile PETSc after making some small
> changes in very few files?
> > Best regards,
> > Thomas
> This message and its contents, including attachments are intended solely
> for the original recipient. If you are not the intended recipient or have
> received this message in error, please notify me immediately and delete
> this message from your computer system. Any unauthorized use or
> distribution is prohibited. Please consider the environment before printing
> this email.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120829/c21b9337/attachment.html>
