[petsc-users] Null space correction depends on solver?
    Thomas Witkowski
    thomas.witkowski at tu-dresden.de
    Tue Aug 28 15:06:43 CDT 2012
Am 28.08.2012 19:57, schrieb Jed Brown:
> On Tue, Aug 28, 2012 at 12:25 PM, Thomas Witkowski
> <thomas.witkowski at tu-dresden.de
> <mailto:thomas.witkowski at tu-dresden.de>> wrote:
>               GMRES uses left preconditioning by default which forces
>         the null space into the Krylov space at each iteration. FGMRES
>         uses right preconditioning and doesn't  do anything to the
>         null space because it is naturally in the Krylov space (since
>         the result with fgmres contains the constants this is why I
>         suspect the matrix actually doesn't have the null space you
>         think it has). You can try running -ksp_type gmres
>         -ksp_pc_side right      my guess is that you will not get near
>         zero for the dot.
>     Any idea how to debug this problem? Lets concentrate on the
>     gmres/no precon case first.
> Left preconditioning and anything using -pc_type none works correctly.
> It is only the case of right preconditioning that is incorrect (and
> needs to be fixed in PETSc).
Is the null space projected out at every iteration step? If so, can you
give me a hint were I can find the corresponding line in source code?
Thanks.
Thomas
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120828/d2c047cf/attachment.html>
