[petsc-users] Null space correction depends on solver?
Barry Smith
bsmith at mcs.anl.gov
Tue Aug 28 11:33:15 CDT 2012
On Aug 28, 2012, at 8:34 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Tue, Aug 28, 2012 at 8:19 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > How to interpret the results? For the first case, is the null space information forwarded to the preconditioner? And even for using just gmres without any preconditioner, the dot product is much closer to zero but still far away.
> Are you sure the null space you provide is truly the null space of the matrix? Call MatNullSpaceTest().
> GMRES uses left preconditioning by default which forces the null space into the Krylov space at each iteration. FGMRES uses right preconditioning and doesn't do anything to the null space because it is naturally in the Krylov space (since the result with fgmres contains the constants this is why I suspect the matrix actually doesn't have the null space you think it has). You can try running -ksp_type gmres -ksp_pc_side right my guess is that you will not get near zero for the dot.
> Barry, it looks like null space removal is not implemented correctly for right preconditioning:
Is this possible to fix? Don't we need the null space of A B , which would require solving with B to get (from the null space of A) and in general we cannot solve with B, only apply it?
Barry
> diff --git a/src/ksp/ksp/examples/tutorials/ex29.c b/src/ksp/ksp/examples/tutorials/ex29.c
> --- a/src/ksp/ksp/examples/tutorials/ex29.c
> +++ b/src/ksp/ksp/examples/tutorials/ex29.c
> @@ -78,6 +78,12 @@
> ierr = KSPSolve(ksp,PETSC_NULL,PETSC_NULL);CHKERRQ(ierr);
> ierr = KSPGetSolution(ksp,&x);CHKERRQ(ierr);
> ierr = KSPGetRhs(ksp,&b);CHKERRQ(ierr);
> + PetscScalar dot;
> + ierr = VecSet(b,1.0);CHKERRQ(ierr);
> + ierr = VecDot(b,x,&dot);CHKERRQ(ierr);
> + ierr = PetscPrintf(PETSC_COMM_WORLD,"dot %g\n",dot);CHKERRQ(ierr);
> ierr = DMDestroy(&da);CHKERRQ(ierr);
> ierr = KSPDestroy(&ksp);CHKERRQ(ierr);
> $ ./ex29 -bc_type neumann -ksp_monitor_true_residual -ksp_test_null_space -mat_null_space_test_view -pc_type jacobi -ksp_pc_side left
> Constants are likely null vector|| A * 1/N || = 0
> 0 KSP preconditioned resid norm 1.135199672180e-01 true resid norm 2.319967097991e-01 ||r(i)||/||b|| 1.000000000000e+00
> 1 KSP preconditioned resid norm 4.410876553096e-02 true resid norm 1.254974589275e-01 ||r(i)||/||b|| 5.409449945916e-01
> 2 KSP preconditioned resid norm 2.255575515098e-02 true resid norm 5.942041105213e-02 ||r(i)||/||b|| 2.561260937863e-01
> 3 KSP preconditioned resid norm 9.933310900089e-03 true resid norm 2.093328265899e-02 ||r(i)||/||b|| 9.023094627987e-02
> 4 KSP preconditioned resid norm 1.073259860881e-17 true resid norm 1.660357840786e-16 ||r(i)||/||b|| 7.156816328229e-16
> dot 1.73472e-16
> $ ./ex29 -bc_type neumann -ksp_monitor_true_residual -ksp_test_null_space -mat_null_space_test_view -pc_type jacobi -ksp_pc_side right
> 0 KSP unpreconditioned resid norm 2.319967097991e-01 true resid norm 2.319967097991e-01 ||r(i)||/||b|| 1.000000000000e+00
> 1 KSP unpreconditioned resid norm 1.218421389101e-01 true resid norm 1.218421389101e-01 ||r(i)||/||b|| 5.251890814123e-01
> 2 KSP unpreconditioned resid norm 5.897341285066e-02 true resid norm 5.897341285066e-02 ||r(i)||/||b|| 2.541993500758e-01
> 3 KSP unpreconditioned resid norm 2.064441965393e-02 true resid norm 2.064441965393e-02 ||r(i)||/||b|| 8.898582946200e-02
> 4 KSP unpreconditioned resid norm 8.019849301680e-17 true resid norm 5.101974804388e-17 ||r(i)||/||b|| 2.199158259100e-16
> dot 0.0188443
> It seems to be caused by this:
> #define KSP_RemoveNullSpace(ksp,y) ((ksp->nullsp && ksp->pc_side == PC_LEFT) ? MatNullSpaceRemove(ksp->nullsp,y,PETSC_NULL) : 0)
