[petsc-users] Null space correction depends on solver?
Thomas Witkowski thomas.witkowski at tu-dresden.de
Tue Aug 28 02:17:28 CDT 2012
Part II of my never ending null space story :) Now I solve Poisson
equation in 3D, discretized with FEM and using free boundaries. In the
PETSc solver part, I added some test to check whether the solution is
still orthogonal to the constant nullspace. The result is somehow hard
to explain. Maybe one of you could spend one minute to give me some
explanation what's going wrong and how to fix it. First, some code snippet:
Vec rhs;
Mat mat;
Vec nsb;
VecDuplicate(rhs, &nsb);
VecSet(nsb, 1.0);
MatNullSpace matNullspace;
MatNullSpaceCreate(MPI::COMM_WORLD, PETSC_TRUE, 0, PETSC_NULL,
&matNullspace);
MatNullSpaceRemove(matNullspace, rhs, PETSC_NULL);
PetscScalar dot;
VecDot(nsb, rhs, &dot);
MSG("TEST 1 = %e\n", dot);
KSP ksp;
KSPCreate(MPI::COMM_WORLD, &kspMat11);
KSPSetOperators(ksp, mat, mat, SAME_NONZERO_PATTERN);
MatSetNullSpace(mat, matNullspace);
KSPSetNullSpace(ksp, matNullspace);
KSPSolve(mat, rhs, rhs);
MSG("TEST 2 = %e\n", dot);
So, nothing really special. Now, I run the code with two different solvers:
1) -ksp_type fgmres -pc_type hypre -pc_hypre_type boomeramg
-pc_hypre_boomeramg_relax_type_coarse Jacobi
                TEST 1 = 5.503931e-14
                TEST 2 = -2.043290e+10
2) -ksp_type gmres -pc_type none
                TEST 2 = 3.195510e-09
How to interpret the results? For the first case, is the null space
information forwarded to the preconditioner? And even for using just
gmres without any preconditioner, the dot product is much closer to zero
but still far away.
Thomas
