[petsc-users] SNES Shell Problems
Mon Aug 27 22:21:03 CDT 2012
On Mon, Aug 27, 2012 at 9:52 PM, Gaetan Kenway <kenway at utias.utoronto.ca>wrote:
> I ran it though the debugger and came up with the following output:
> (gdb) backtrace
> #0  0x00000000 in ?? ()
> #1  0xb5fd2832 in oursnesshellsolve (snes=0xbb03d30, x=0xbb2a4f0) at
> /nfs/mica/home/kenway/Downloads/petsc-3.3/src/snes/impls/shell/ftn-custom/zsnesshellf.c:13
How are you calling SNESShellSetSolve(). The usage we expected was that you
would
call SNESSetFromOptions(snes,ierr)
call SNESGetPC(snes,snespc,ierr)
call SNESShellSetSolve(snespc,yourfunction,ierr)
> #2  0xb6017009 in SNESSolve_Shell (snes=0xbb03d30) at
> /nfs/mica/home/kenway/Downloads/petsc-3.3/src/snes/impls/shell/snesshell.c:169
> #3  0xb60032e8 in SNESSolve (snes=0xbb03d30, b=0xb8c0610, x=0xbb2a4f0) at
> /nfs/mica/home/kenway/Downloads/petsc-3.3/src/snes/interface/snes.c:3536
> #4  0xb6041547 in SNESSolve_NGMRES (snes=0xb8c1f70) at
> /nfs/mica/home/kenway/Downloads/petsc-3.3/src/snes/impls/ngmres/snesngmres.c:259
> #5  0xb60032e8 in SNESSolve (snes=0xb8c1f70, b=0xb8c0610, x=0xb8ba6f0) at
> #6  0xb5fd0e73 in snessolve_ (snes=0xb4d75a2c, b=0xb4d75c6c, x=0xb4d75c68,
> __ierr=0xbfffe338)
>     at
> /nfs/mica/home/kenway/Downloads/petsc-3.3/src/snes/interface/ftn-custom/zsnesf.c:181
> #7  0xb47791f3 in nksolver2 () at NKSolver2.F90:20
> #8  0xb46f8f68 in solvestate () at solveState.F90:485
> #9  0xb46f95c2 in solversteady () at solverSteady.f90:27
> #10 0xb46f9257 in solver () at solver.F90:102
> #11 0x0b8ba2c0 in ?? ()
> #12 0xb464a222 in f2py_rout_sumb_solver () from /tmp/tmpTaGWsk/sumb.so
> #13 0xb46454e5 in fortran_call () from /tmp/tmpTaGWsk/sumb.so
> #14 0x0805fd6a in PyObject_Call ()
> #15 0x080dd5b0 in PyEval_EvalFrameEx ()
> #16 0x080dfbb2 in PyEval_EvalCodeEx ()
> #17 0x08168f1f in ?? ()
> #18 0x0805fd6a in PyObject_Call ()
> #19 0x080dcbeb in PyEval_EvalFrameEx ()
> #20 0x080dfbb2 in PyEval_EvalCodeEx ()
> #21 0x08168e3c in ?? ()
> #22 0x0805fd6a in PyObject_Call ()
> #23 0x08067d5c in ?? ()
> #24 0x0805fd6a in PyObject_Call ()
> #25 0x080b3554 in ?? ()
> #26 0x0805fd6a in PyObject_Call ()
> #27 0x080dd5b0 in PyEval_EvalFrameEx ()
> #28 0x080dfbb2 in PyEval_EvalCodeEx ()
> #29 0x080dfca7 in PyEval_EvalCode ()
> #30 0x080fd956 in PyRun_FileExFlags ()
> #31 0x080fdbb2 in PyRun_SimpleFileExFlags ()
> #32 0x0805b6d3 in Py_Main ()
> #33 0x0805a8ab in main ()
> I'm also 99% certain that the function in set correctly since the shell
> snes works just fine when it is called directly. (see some of the earlier
> code snippits). Its only when I'm trying to use it as the preconditioner
> for the another snes object (ngmres) I have issues.
> Gaetan
> On Mon, Aug 27, 2012 at 10:34 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>> On Mon, Aug 27, 2012 at 7:31 PM, Gaetan Kenway <kenway at utias.utoronto.ca>wrote:
>>> Unfortunately I can run backtraces since the code is running from python
>>> and the -on_error_attach_debugger option has no effect when you're running
>>> from python.
>> You can use -start_in_debugger, then type "c" (for "continue") at the gdb
>> prompt.
>>> The petsc4py is initialized with:
>>> import petsc4py
>>> petsc4py.init(args=sys.argv)
>>> so other options are passed in just fine.
>>> I ran it with valgrind and got the following:
>>> ==15046== Jump to the invalid address stated on the next line
>>> ==15046==    at 0x0: ???
>>> ==15046==    by 0x95EF008: SNESSolve_Shell (snesshell.c:169)
>>> ==15046==    by 0x95DB2E7: SNESSolve (snes.c:3536)
>>> ==15046==    by 0x9619546: SNESSolve_NGMRES (snesngmres.c:259)
>>> ==15046==    by 0x95A8E72: snessolve_ (zsnesf.c:181)
>>> ==15046==    by 0x9AEA302: nksolver2_ (NKSolver2.F90:20)
>>> ==15046==    by 0x9A6A077: solvestate_ (solveState.F90:485)
>>> ==15046==    by 0x9A6A6D1: solversteady_ (solverSteady.f90:27)
>>> ==15046==    by 0x99BB1C1: f2py_rout_sumb_solver (in
>>> /tmp/tmpGQGZda/sumb.so)
>>> ==15046==    by 0x99B6484: fortran_call (in /tmp/tmpGQGZda/sumb.so)
>>> ==15046==    by 0x805FD69: PyObject_Call (in /usr/bin/python2.6)
>>> ==15046==  Address 0x0 is not stack'd, malloc'd or (recently) free'd
>> This looks like SNESShellSetSolve() did not work. Are you sure that the
>> type was set (e.g. SNESSetType() or SNESSetFromOptions()) before you called
>> SNESShellSetSolve()?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120827/0e0b29e1/attachment.html>
