[petsc-users] SNES Shell Problems
Mon Aug 27 21:34:11 CDT 2012
On Mon, Aug 27, 2012 at 7:31 PM, Gaetan Kenway <kenway at utias.utoronto.ca>wrote:
> Unfortunately I can run backtraces since the code is running from python
> and the -on_error_attach_debugger option has no effect when you're running
> from python.
You can use -start_in_debugger, then type "c" (for "continue") at the gdb
prompt.
> The petsc4py is initialized with:
> import petsc4py
> petsc4py.init(args=sys.argv)
> so other options are passed in just fine.
> I ran it with valgrind and got the following:
> ==15046== Jump to the invalid address stated on the next line
> ==15046==    at 0x0: ???
> ==15046==    by 0x95EF008: SNESSolve_Shell (snesshell.c:169)
> ==15046==    by 0x95DB2E7: SNESSolve (snes.c:3536)
> ==15046==    by 0x9619546: SNESSolve_NGMRES (snesngmres.c:259)
> ==15046==    by 0x95A8E72: snessolve_ (zsnesf.c:181)
> ==15046==    by 0x9AEA302: nksolver2_ (NKSolver2.F90:20)
> ==15046==    by 0x9A6A077: solvestate_ (solveState.F90:485)
> ==15046==    by 0x9A6A6D1: solversteady_ (solverSteady.f90:27)
> ==15046==    by 0x99BB1C1: f2py_rout_sumb_solver (in
> /tmp/tmpGQGZda/sumb.so)
> ==15046==    by 0x99B6484: fortran_call (in /tmp/tmpGQGZda/sumb.so)
> ==15046==    by 0x805FD69: PyObject_Call (in /usr/bin/python2.6)
> ==15046==  Address 0x0 is not stack'd, malloc'd or (recently) free'd
This looks like SNESShellSetSolve() did not work. Are you sure that the
type was set (e.g. SNESSetType() or SNESSetFromOptions()) before you called
SNESShellSetSolve()?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120827/231443c5/attachment.html>
