[petsc-users] SNES Shell Problems
Gaetan Kenway
kenway at utias.utoronto.ca
Mon Aug 27 16:06:53 CDT 2012
Thanks very much for the very quick response.
I will pull the change from the mercurial repository and give it a try in
the next couple of days.
Gaetan
On Mon, Aug 27, 2012 at 3:59 PM, Peter Brune <brune at mcs.anl.gov> wrote:
> I've tested and pushed a fix to petsc-3.3. If there are any problems, let
> me know.
> On Mon, Aug 27, 2012 at 12:24 PM, Gaetan Kenway <kenway at utias.utoronto.ca>wrote:
>> Excellent. Thanks.
>> The reason for using the snes shell solver is I would like to try out the
>> ngmres snes. solver. The code I'm working with already has a has a
>> non-linear multi-grid method, coded directly in the fortran source. My plan
>> was to setup the the ngmres snes solver, then create a snes shell as the
>> preconditioner that wraps the nonlienear multigrid solver already in place.
>> Does this make sense? Is this the sort of usage you had in mind?
> This is very much the usage we were intending for this.
> - Peter
>> Thanks,
>> Gaetan
>> On Mon, Aug 27, 2012 at 1:10 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>>> On Mon, Aug 27, 2012 at 12:09 PM, Gaetan Kenway <
>>> kenway at utias.utoronto.ca> wrote:
>>>> That's what I had deduced. I tried modifying the source code taking out
>>>> the 'C', but it still didn't seem to generate the required wrapper. Does
>>>> the functions that get passed function pointer handle's require special
>>>> handling?
>>> It needs custom handling. Peter is working on it.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120827/be782480/attachment.html>
