[petsc-users] SNES Shell Problems
Gaetan Kenway kenway at utias.utoronto.ca
Mon Aug 27 12:24:58 CDT 2012
Excellent. Thanks.
The reason for using the snes shell solver is I would like to try out the
ngmres snes. solver. The code I'm working with already has a has a
non-linear multi-grid method, coded directly in the fortran source. My plan
was to setup the the ngmres snes solver, then create a snes shell as the
preconditioner that wraps the nonlienear multigrid solver already in place.
Does this make sense? Is this the sort of usage you had in mind?
Gaetan
On Mon, Aug 27, 2012 at 1:10 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Mon, Aug 27, 2012 at 12:09 PM, Gaetan Kenway <kenway at utias.utoronto.ca>wrote:
>> That's what I had deduced. I tried modifying the source code taking out
>> the 'C', but it still didn't seem to generate the required wrapper. Does
>> the functions that get passed function pointer handle's require special
>> handling?
> It needs custom handling. Peter is working on it.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120827/2253ab2f/attachment.html>
