[petsc-users] compare: performance of petsc_3.3p2 and petsc_dev-r24197
Matthew Knepley
knepley at gmail.com
Wed Aug 22 06:07:33 CDT 2012
On Wed, Aug 22, 2012 at 5:52 AM, Feng Li <fengshen186 at gmail.com> wrote:
> Thank you for your help!
> The log_summary result is in the attachment.
> Please kindly check the attachment!
This is not a PETSc change, its a PFLOTRAN change. You have changed the way
the Jacobian is evaluated. Look at the 3.3 log
SNESSolve 18 1.0 1.2947e+01 1.0 1.22e+09 1.0 0.0e+00 0.0e+00
0.0e+00 44 83 0 0 0 93100 0 0 0 94
SNESFunctionEval 39 1.0 3.3130e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
0.0e+00 11 0 0 0 0 24 0 0 0 0 0
SNESJacobianEval 21 1.0 4.2020e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
0.0e+00 14 0 0 0 0 30 0 0 0 0 0
SNESLineSearch 21 1.0 1.8140e+00 1.0 4.82e+06 1.0 0.0e+00 0.0e+00
0.0e+00 6 0 0 0 0 13 0 0 0 0 3
KSPGMRESOrthog 470 1.0 8.2534e-01 1.0 7.25e+08 1.0 0.0e+00 0.0e+00
0.0e+00 3 50 0 0 0 6 59 0 0 0 879
against the dev log
SNESSolve 18 1.0 4.3973e+01 1.0 1.22e+09 1.0 0.0e+00 0.0e+00
0.0e+00 40 83 0 0 0 98100 0 0 0 28
SNESFunctionEval 39 1.0 3.2787e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
0.0e+00 3 0 0 0 0 7 0 0 0 0 0
SNESJacobianEval 21 1.0 3.5318e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
0.0e+00 32 0 0 0 0 79 0 0 0 0 0
SNESLineSearch 21 1.0 1.8007e+00 1.0 4.82e+06 1.0 0.0e+00 0.0e+00
0.0e+00 2 0 0 0 0 4 0 0 0 0 3
KSPGMRESOrthog 470 1.0 8.0665e-01 1.0 7.25e+08 1.0 0.0e+00 0.0e+00
0.0e+00 1 50 0 0 0 2 59 0 0 0 899
The huge difference here comes from the Jacobian evaluation, which we do
not control.
Matt
> 2012/8/22 Aron Ahmadia <aron.ahmadia at kaust.edu.sa>
>> Can you re-run both codes with: -log_summary please?
>> A
>> On Wed, Aug 22, 2012 at 10:43 AM, Feng Li <fengshen186 at gmail.com> wrote:
>> > The performance of petsc_3.3p2 is five times faster than
>> petsc_dev-r24197.
>> > Why?
>> > It is tested with pflotran example problem 100x100x100.
>> > config parameter:--with-mpi=0 --CC=gcc --FC=gfortran --CCFLAGS="-g -O2"
>> > --FCFLAGS="-g -O2" --blas-lapack-dir=$MKLROOT
>> > detail time:
>> > petsc_3.3p2 petsc_dev24197
>> > walltime(sec) 28.116 110.25
>> > Thank you!
>> This message and its contents, including attachments are intended solely
>> for the original recipient. If you are not the intended recipient or have
>> received this message in error, please notify me immediately and delete
>> this message from your computer system. Any unauthorized use or
>> distribution is prohibited. Please consider the environment before
>> printing
>> this email.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120822/869f8cc8/attachment.html>
