[petsc-users] compare: performance of petsc_3.3p2 and petsc_dev-r24197
Aron Ahmadia
aron.ahmadia at kaust.edu.sa
Wed Aug 22 05:06:53 CDT 2012
Can you re-run both codes with: -log_summary please?
A
On Wed, Aug 22, 2012 at 10:43 AM, Feng Li <fengshen186 at gmail.com> wrote:
> The performance of petsc_3.3p2 is five times faster than petsc_dev-r24197.
> Why?
> It is tested with pflotran example problem 100x100x100.
> config parameter:--with-mpi=0 --CC=gcc --FC=gfortran --CCFLAGS="-g -O2"
> --FCFLAGS="-g -O2" --blas-lapack-dir=$MKLROOT
> detail time:
> petsc_3.3p2 petsc_dev24197
> walltime(sec) 28.116 110.25
> Thank you!
This message and its contents, including attachments are intended solely
for the original recipient. If you are not the intended recipient or have
received this message in error, please notify me immediately and delete
this message from your computer system. Any unauthorized use or
distribution is prohibited. Please consider the environment before printing
this email.
