[petsc-users] MatMatSolve in sequential call
Alexander Grayver agrayver at gfz-potsdam.de
Tue Aug 21 11:42:02 CDT 2012
On 21.08.2012 18:32, Matthew Knepley wrote:
>     MUMPS takes only several minutes and 6 GB of memory to factorize it.
>     This factorization gives residual on the order of 10e-12 and
>     solution is indeed correct.
>     Nevertheless, you're right, there is numerical null-space in this
>     matrix since it comes
>     from the discretization of equation that contains curl curl
>     operator, but practically this
>     case is not really the worst one.
> This makes no sense whatsoever. How can you LU factor a matrix that
> has a null space?
Matt,
I'm not sure that I correctly used term numerical null-space in my post.
The equation is
curl curl E + kE = -J,
where k is a function of frequency and conductivity, whenever one of
them becomes small this term gets vanishingly small thus we have
problems since curl curl operator has nontrivial null-space by
definition. So let's say solving this equation for low frequencies and
for models containing air is difficult.
What kind of magic is inside MUMPS I don't know, but it is able to
handle such cases (e.g. SuperLU and PaStiX fail).
Also, if it matters, I'm talking about LDLt factorization in MUMPS.
Alexander
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120821/a7ca9f40/attachment.html>
