[petsc-users] Solving upper triangular system with pc fieldsplit
Matthew Knepley
knepley at gmail.com
Mon Aug 20 07:29:24 CDT 2012
On Mon, Aug 20, 2012 at 7:18 AM, Thomas Witkowski <
thomas.witkowski at tu-dresden.de> wrote:
> Am 20.08.2012 13:39, schrieb Matthew Knepley:
> On Mon, Aug 20, 2012 at 3:09 AM, Thomas Witkowski <
>> Is it possible to change the PCFIELDSPLIT / block Gauss-Seidel
>> preconditioner to use A_01 instead of A_10 to solve an upper triangular
>> system?
> It always uses A_01. What exactly do you want to do?
> In this case the documentation should be changed (see p. 86)
I did not understand your question. The correct answer is: You can define
fields
in any order.
Matt
> Thomas
> Matt
>> Thomas
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120820/dd207c73/attachment-0001.html>
