[petsc-users] How to use AD for unstructured grid
Jed Brown
jedbrown at mcs.anl.gov
Mon Aug 20 00:25:32 CDT 2012
This is a choice for you to make. Operator overloading is usually less
intrusive to use, but also more limited in capability.
On Mon, Aug 20, 2012 at 12:24 AM, behzad baghapour <
behzad.baghapour at gmail.com> wrote:
> Dear Jed,
> Which AD tool you suggest in the case of fast evaluations? Operator
> Overlapping types like ADOL-C or source code transformation types like ADIC?
> In addition, I prefer the minimum possible change to the my code structure
> Thanks a lot,
> BehZad
> On Sun, Aug 19, 2012 at 10:06 PM, behzad baghapour <
>> OK. Thanks. I should try it.
>> On Sun, Aug 19, 2012 at 9:56 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>>> On Sun, Aug 19, 2012 at 1:19 PM, behzad baghapour <
>>>> Dear developers,
>>>> I need to evaluate Jacobian matrix using an AD tool. I read from the
>>>> Petsc manual that it can only work with structured grid via DMMG interface.
>>>> Is there a possible way to use it for unstructured grid and set it for KSP
>>>> structure?
>>> ADIC has not been supported for a long time so the "automatic" AD
>>> support in PETSc is no longer supported either. Unfortunately, the
>>> successors to ADIC, while more "capable", are much more involved to build
>>> and to use.
>>> You have always been able to use any AD tool internally to define the
>>> Jacobian (in assembled or unassembled form).
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120820/0f6d0d14/attachment.html>
