[petsc-users] Composite shell preconditiner
Alexander Grayver
agrayver at gfz-potsdam.de
Sat Aug 18 02:40:23 CDT 2012
Barry,
This was my original idea before I started trying pccomposite stuff.
I will stick to it, thank you for pointing it out.
On 17.08.2012 22:34, Barry Smith wrote:
> On Aug 17, 2012, at 8:54 AM, Alexander Grayver <agrayver at gfz-potsdam.de> wrote:
>> you want to compute c?
>> I was planning to do it inside ShellPCApply.
>> The correction itself is calculated as a solution of Poisson equation with rhs being divergence of current density and current density is calculated based on x_i
> A preconditioner step can only be written in the form c = B(b - A x_i) where B is any linear operator and b is the right hand side and A is the original operator. So if your calculation of c of this form (note that you need not form B explicitly as a sparse matrix but it must be some linear operator. From you description above "with rhs being divergence of current density and current density is calculated based on x_i" I suspect it cannot be written in this form.
> The way to write this is
> KSPSetInitialGuessNonzero(kspmain);
> KSPSetTolerance(kspmain, set number of inner iterations you wish to use before the "filtering step"
> for j=1,….. number outer iterations
> KSPSolve(kspmain,b,x)
> compute rhs via "rhs being divergence of current density and current density is calculated based on x_i"
> KSPSolve(ksppoisson,rhs,c)
> x = x + c
> endfor
> I don't think you can, or want to "munge" it into some kind of single complicated KSPSolve
Alexander
