[petsc-users] Nullspace for a coupled system of equations
Thomas Witkowski thomas.witkowski at tu-dresden.de
Fri Aug 17 14:27:20 CDT 2012
On Fri, Aug 17, 2012 at 3:10 AM, Thomas Witkowski
<thomas.witkowski at tu-dresden.de <mailto:thomas.witkowski at tu-dresden.de>>
wrote:
>>         I want to solve some (weakly) coupled system of equations of
>>         the following form:
>>         A  B     u
>>         0  C     v
>>         so, C is the discrete Laplacian and A and B are some more
>>         complicated operators (I make use of linear finite elements).
>>         All boundary conditions are periodic, so the unknown v is
>>         determined only up to a constant. A and B contain both the
>>         identity operator, so u is fixed. Now I want to solve the
>>         system on the whole (there are reasons to do it in this way!)
>>         and I must provide information about the nullspace to the
>>         solver. When I am right, to provide the correct nullspace I
>>         must solve one equation with A. Is there any way in PETSc to
>>         circumvent the problem?
>>     If I understand you correctly, your null space vector is (0 I). I
>>     use the same null space for SNES ex62.
>     (0 I) cannot be an element of the null space, as multiplying it
>     with the matrix results in a non-zero vector. Or am I totally
>     wrong about null spaces of matrices?
> Maybe you could as your question again. I am not understanding what
> you want.
I want to solve the block triangular system as described above. My
problem is, that it has a one dimensional null space, but I'm not able
to define it. My question is: does anyone can give me an advice how to
EITHER compute the null space explicitly OR how to solve the system in
such a way that the null space is considered by the solver. The only
constraint is that I cannot split the system of equations into two
independent solve for both variables. I know that from this description
its not clear why there is this constraint, but it would take too long
to describe it.
Thomas
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120817/e2c69fa5/attachment-0001.html>
