[petsc-users] issue with different versions of petsc-dev
Mohammad Mirzadeh mirzadeh at gmail.com
Fri Aug 17 14:20:11 CDT 2012
You mean columns within a row? Nope.
On Fri, Aug 17, 2012 at 12:18 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Fri, Aug 17, 2012 at 2:11 PM, Mohammad Mirzadeh <mirzadeh at gmail.com>wrote:
>> Hi guys,
>> I just realize my code breaks with new versions of petsc-dev. I use
>> MatCreateMPIAIJWithSplitArrays() funtions and it works with this verison:
>> Petsc Development HG revision: b27fc9457bdc002c5a5de2b07797ae1a93094370
>>  HG Date: Thu May 03 13:42:15 2012 -0500
>> but breaks with:
>> Petsc Development HG revision: f9c6cac2d69c724a2258d4e0dc2f51b0825aa875
>>  HG Date: Thu Aug 16 08:37:18 2012 -0700
>> Here's the error code:
>> [0]PETSC ERROR: --------------------- Error Message
>> [0]PETSC ERROR: Argument out of range!
>> [0]PETSC ERROR: Column entry number 1 (actual colum 2) in row 3 is not
>> sorted!
> Are your rows sorted?
>>  [0]PETSC ERROR:
>> [0]PETSC ERROR: Petsc Development HG revision:
>> f9c6cac2d69c724a2258d4e0dc2f51b0825aa875  HG Date: Thu Aug 16 08:37:18 2012
>> -0700
>> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
>> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>> [0]PETSC ERROR: See docs/index.html for manual pages.
>> [0]PETSC ERROR:
>> [0]PETSC ERROR: ./FVM on a arch-linu named mohammad-desktop by mohammad
>> Fri Aug 17 12:06:15 2012
>> [0]PETSC ERROR: Libraries linked from
>> /home/mohammad/soft/petsc-dev_new/petsc-dev/arch-linux2-cxx-debug/lib
>> [0]PETSC ERROR: Configure run at Fri Aug 17 11:45:31 2012
>> [0]PETSC ERROR: Configure options --with-clanguage=cxx
>> --with-mpi-dir=/usr/bin --download-f-blas-lapack=1 --download-hypre=1
>> --download-parmetis=1 --download-metis=1 --download-superlu_dist=1
>> [0]PETSC ERROR:
>> [0]PETSC ERROR: MatCreateSeqAIJWithArrays() line 4268 in
>> /home/mohammad/soft/petsc-dev_new/petsc-dev/src/mat/impls/aij/seq/aij.c
>> [0]PETSC ERROR: MatCreateMPIAIJWithSplitArrays() line 5731 in
>> /home/mohammad/soft/petsc-dev_new/petsc-dev/src/mat/impls/aij/mpi/mpiaij.c
>> [0]PETSC ERROR: setLinearSystemMatrix() line 84 in
>> "unknowndirectory/"../../../CASL/lib/algebra/petscLinearSolver.cpp
>> Is there anything changed regarding numbering of diagonal and
>> off-diagonal entries when using the said function between these two
>> versions?
>> Thanks,
>> Mohammad
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120817/ac39d745/attachment.html>
