[petsc-users] Scatter context for MatMult
    Jed Brown
    jedbrown at mcs.anl.gov
    Fri Aug 17 13:33:55 CDT 2012
On Fri, Aug 17, 2012 at 1:05 PM, John Fettig <john.fettig at gmail.com> wrote:
> Is this the role of MatGetGhosts?
That's the intent, but it looks like this function was only implemented for
MPIBAIJ.
The actual implementation of MatMult_MPI*AIJ is to start the scatter, apply
the diagonal block, finish the scatter, and apply the off-diagonal part.
Why do you want raw access?
If you really need, you can either use MatMPIAIJGetSeqAIJ() or just include
the private header.
> John
> On Fri, Aug 17, 2012 at 2:01 PM, John Fettig <john.fettig at gmail.com>
> wrote:
> > Is there a scatter context available someplace that would allow me to
> > gather all of the elements of a vector that correspond to the ones
> > needed for a MatMult (MPIAIJ matrices)?  When you do a MatMult, I
> > presume it first scatters/gathers the ghost elements of the vector
> > being multiplied, can I use this scatter for a vectors outside of the
> > MatMult?
> > Thanks,
> > John
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120817/466ebd08/attachment-0001.html>
