[petsc-users] Segmentation fault when using matlab interface
Fri Aug 17 10:50:14 CDT 2012
one issue with linking to 64bit matlab is: it internally links in with
64int mlk/blas [packaged in matlab]. So I think we have to use this
mkl with petsc [along with -known-64-bit-blas-indices=1 option]
But there should be no calls to blas with just petscinitialize/finalize.
Perhaps its possible to run this in a debugger to determine the exact reason for SEGV?
Satish
On Fri, 17 Aug 2012, De Groof, Vincent wrote:
> Well, basically the simplest program I have the problem with is initializing and finalizing petsc.
> % Set environment variables.
> setenv('PETSC_DIR', '/usr/local/petsc-3.3-p2/')
> setenv('PETSC_ARCH','arch-linux2-c-debug')
> % Call PETSc.
> PetscInitialize();
> PetscFinalize();
> thanks.
> ________________________________
> Von: De Groof, Vincent
> Gesendet: Freitag, 17. August 2012 10:25
> An: petsc-users at mcs.anl.gov
> Betreff: Segmentation fault when using matlab interface
> Hello,
> I'm trying to use the Petsc objects directly from Matlab. However, when testing the examples in the /bin/matlab/classes/examples/tutorials-directory, I get a segmentation fault (core dump) error. Unfortunately, I don't get more information then this. After running some different situations, I know the following:
> I ran matlab both with and without desktop. The only error message I get is the segmentation fault. Sometimes it doesn't give the segmentation error after running the example. If so, it will cause a segmentation fault upon entering the next command in the matlab shell. If I quit matlab immediately after running an example without segmentation fault, my unix shell will hang.
> I know it's kind of vague, but this is all I know now. Any suggestions to look at to solve this problem?
> thanks.
