[petsc-users] Composite shell preconditiner
Alexander Grayver
agrayver at gfz-potsdam.de
Fri Aug 17 09:42:21 CDT 2012
Jed,
I do see the drawbacks of this method, but it seems to have good
scalability.
That I want to test.
Thank you.
On 17.08.2012 16:32, Jed Brown wrote:
> On Fri, Aug 17, 2012 at 9:23 AM, Alexander Grayver
> <agrayver at gfz-potsdam.de <mailto:agrayver at gfz-potsdam.de>> wrote:
> Right.
> Could you please explain what do you mean by fragile?
> Fragile means unreliable. The math is not right for Krylov methods in
> general. You are relying on side-effects of particular methods and
> preconditioner side combinations. Fragile is the opposite of "robust".
> For a "robust" method, you should start with a compatible
> discretization and/or choose a preconditioner that is stable on the
> quasi-null space and/or filter in a way that is consistent with the
> Krylov method (e.g. as described using FGMRES).
>> Looks a bit tricky. The number of fgmres iterations then
>> defines number of the cycles correction will be applied,
>> doesn't it?
>> Yes.
> If I do this command line only setup:
> -pc_type composite -pc_composite_type multiplicative
> -pc_composite_pcs ksp,shell
> How does petsc know what ShellPCApply routine to take? I guess I
> have to specify this in the code anyway?
> Yeah, to select your preconditioner in this way, you should name it
> preconditioner something meaningful and use PCRegisterDynamic() just
> like the native implementations.
Alexander
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120817/05650d90/attachment.html>
