[petsc-users] Composite shell preconditiner
Alexander Grayver agrayver at gfz-potsdam.de
Fri Aug 17 09:23:54 CDT 2012
On 17.08.2012 16:03, Jed Brown wrote:
> Fine, sounds like you are doing divergence cleaning for an
> incompatible spatial discretization. Since the change lies within the
> null space of the intended continuous operator, you should be okay.
> But note that this procedure is fragile and will have different effect
> with different Krylov methods and preconditioning sides.
Right.
Could you please explain what do you mean by fragile?
>     Looks a bit tricky. The number of fgmres iterations then defines
>     number of the cycles correction will be applied, doesn't it?
> Yes.
If I do this command line only setup:
-pc_type composite -pc_composite_type multiplicative -pc_composite_pcs
ksp,shell
How does petsc know what ShellPCApply routine to take? I guess I have to
specify this in the code anyway?
Alexander
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120817/acd67b6b/attachment.html>
