[petsc-users] Composite shell preconditiner
Alexander Grayver agrayver at gfz-potsdam.de
Fri Aug 17 07:48:11 CDT 2012
Hello petsc team!
I would like to apply some sort of correction during Krylov process
every N iterations.
So I decided to use composite preconditioner like that:
-pc_type composite -pc_composite_pcs shell,sor/icc/gamg
I've started to test with the simplest shell preconditioner that does
nothing:
subroutine ShellPCApply(pc,x,y,ierr)
   implicit none
#include "finclude/petscsys.h"
#include "finclude/petscvec.h"
   PC,intent(in)        :: pc
   Vec,intent(in)       :: x
   Vec,intent(inout)    :: y
   call VecCopy(x,y,ierr);CHKERRQ(ierr)
endsubroutine ShellPCApply
And it turned out that this influences convergence by itself. In case:
Linear solve converged due to CONVERGED_RTOL iterations 125
whereas
-pc_type composite -pc_composite_pcs sor
Linear solve converged due to CONVERGED_RTOL iterations 35
Why does it happen? What is the right way to go then?
Thanks in advance.
Just in case, here is -ksp_view for -pc_composite_pcs shell,sor :
PC Object:() 1 MPI processes
   type: composite
   Composite PC type - ADDITIVE
   PCs on composite preconditioner follow
     PC Object:    (sub_0_)     1 MPI processes
       type: shell
         Shell: no name
       linear system matrix = precond matrix:
       Matrix Object:       1 MPI processes
         type: seqaij
         rows=59049, cols=59049
         total: nonzeros=741555, allocated nonzeros=767637
         total number of mallocs used during MatSetValues calls =0
           not using I-node routines
     PC Object:    (sub_1_)     1 MPI processes
       type: sor
         SOR: type = local_symmetric, iterations = 1, local iterations =
1, omega = 1
         type: seqaij
     type: seqaij
Alexander
