[petsc-users] Strange behavior of MatLUFactorNumeric()
Tue Aug 14 17:52:27 CDT 2012
On Tue, Aug 14, 2012 at 5:39 PM, Jinquan Zhong <jzhong at scsolutions.com>wrote:
>  Thanks, Matt.****
> **1.       **Yes, I have checked the returned values from x obtained from*
> MatSolve(F,b,x)****
>                 The norm error check for x is complete for N=75, 2028.
If this is C, I want to see
  ierr = MatSolev(F, b, x);CHKERRQ(ierr);
    Matt
> **2.       **Good point, Matt.  Here is the complete message for Rank
> 391.  The others are similar to this one.****
> [391]PETSC ERROR:
> [391]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> probably memory access out of range****
> [391]PETSC ERROR: Try option -start_in_debugger or
> -on_error_attach_debugger****
> [391]PETSC ERROR: or see
> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[391]PETSCERROR: or try
> http://valgrind.org on GNU/linux and Apple Mac OS X to find memory
> corruption errors****
> [391]PETSC ERROR: likely location of problem given in stack below****
> [391]PETSC ERROR: ---------------------  Stack Frames
> [391]PETSC ERROR: Note: The EXACT line numbers in the stack are not
> available,****
> [391]PETSC ERROR:       INSTEAD the line number of the start of the
> function****
> [391]PETSC ERROR:       is given.****
> [391]PETSC ERROR: [391] MatLUFactorNumeric_SuperLU_DIST line 284
> /nfs/06/com0488/programs/libraries/PETSc/petsc-3.3-p2/src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c
> [391]PETSC ERROR: [391] MatLUFactorNumeric line 2778
> /nfs/06/com0488/programs/libraries/PETSc/petsc-3.3-p2/src/mat/interface/matrix.c
> [391]PETSC ERROR: --------------------- Error Message
> [391]PETSC ERROR: Signal received!****
> [391]PETSC ERROR:
> [391]PETSC ERROR: Petsc Release Version 3.3.0, Patch 2, Fri Jul 13
> 15:42:00 CDT 2012****
> [391]PETSC ERROR: See docs/changes/index.html for recent updates.****
> [391]PETSC ERROR: See docs/faq.html for hints about trouble shooting.****
> [391]PETSC ERROR: See docs/index.html for manual pages.****
> [391]PETSC ERROR:
> [391]PETSC ERROR: /nfs/06/com0488/programs/examples/ZSOL0.2431/ZSOL on a
> arch-linu named n0272.ten.osc.edu by com0488 Sun Aug 12 23:18:07 2012****
> [391]PETSC ERROR: Libraries linked from
> /nfs/06/com0488/programs/libraries/PETSc/petsc-3.3-p2/arch-linux2-cxx-debug/lib
> [391]PETSC ERROR: Configure run at Fri Aug  3 17:44:00 2012****
> [391]PETSC ERROR: Configure options
> --with-blas-lib=/nfs/06/com0488/programs/libraries/ScaLAPACK/2.0.1/lib/librefblas.a
> --with-lapack-lib=/nfs/06/com0488/programs/libraries/ScaLAPACK/2.0.1/lib/libreflapack.a
> --download-blacs --download-scalapack
> --with-mpi-dir=/usr/local/mvapich2/1.7-gnu
> --with-mpiexec=/usr/local/bin/mpiexec --with-scalar-type=complex
> --with-precision=double --with-clanguage=cxx --with-fortran-kernels=generic
> --download-mumps --download-superlu_dist --download-parmetis
> --download-metis --with-fortran-interfaces[391]PETSC ERROR:
> [391]PETSC ERROR: User provided function() line 0 in unknown directory
> unknown file****
> [cli_391]: aborting job:****
> application called MPI_Abort(MPI_COMM_WORLD, 59) - process 391****
> *From:* petsc-users-bounces at mcs.anl.gov [mailto:
> petsc-users-bounces at mcs.anl.gov] *On Behalf Of *Matthew Knepley
> *Sent:* Tuesday, August 14, 2012 3:34 PM
> *To:* PETSc users list
> *Subject:* Re: [petsc-users] Strange behavior of MatLUFactorNumeric()****
> On Tue, Aug 14, 2012 at 5:26 PM, Jinquan Zhong <jzhong at scsolutions.com>
> wrote:****
>   Dear PETSc folks,****
> I have a strange observation on using MatLUFactorNumeric() for dense
> matrices at different order N.  Here is the situation I have:****
> 1.       I use ./src/mat/tests/ex137.c as an example to direct PETSc in
> selecting superLU-dist and mumps.  The calling sequence is ****
> MatGetOrdering(A,…)****
> MatGetFactor(A,…)****
> MatLUFactorSymbolic(F, A,…)****
> *MatLUFactorNumeric*(F, A,…)****
> MatSolve(F,b,x)****
> 2.       I have three dense matrices A at three different dimensions:
> N=75, 2028 and 21180.  ****
> 3.       The calling sequence works for N=75 and 2028.  But when N=21180,
> the program hanged up when calling *MatLUFactorNumeric*(…).  Seemed to be
> a segmentation fault with the following error message:****
> [1]PETSC ERROR: --------------------- Error Message
> [1]PETSC ERROR: Signal received!****
> ALWAYS send the entire error message. How can we tell anything from a
> small snippet?****
> Since you have [1], this was run in parallel, so you need 3rd party
> packages. But you do****
> not seem to be checking return values. Check them to make sure those
> packages are installed****
> correctly.****
>    Matt****
>   Does anybody have similar experience on that?****
> Thanks a lot!****
> Jinquan****
> experiments lead.
> -- Norbert Wiener****
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120814/e8eabc2c/attachment.html>
