[petsc-users] Strange behavior of MatLUFactorNumeric()
Jinquan Zhong
jzhong at scsolutions.com
Tue Aug 14 17:26:39 CDT 2012
Dear PETSc folks,
I have a strange observation on using MatLUFactorNumeric() for dense matrices at different order N. Here is the situation I have:
1. I use ./src/mat/tests/ex137.c as an example to direct PETSc in selecting superLU-dist and mumps. The calling sequence is
MatGetOrdering(A,…)
MatGetFactor(A,…)
MatLUFactorSymbolic(F, A,…)
MatLUFactorNumeric(F, A,…)
MatSolve(F,b,x)
2. I have three dense matrices A at three different dimensions: N=75, 2028 and 21180.
3. The calling sequence works for N=75 and 2028. But when N=21180, the program hanged up when calling MatLUFactorNumeric(…). Seemed to be a segmentation fault with the following error message:
[1]PETSC ERROR: --------------------- Error Message ------------------------------------
[1]PETSC ERROR: Signal received!
Does anybody have similar experience on that?
Thanks a lot!
Jinquan
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120814/ae93d114/attachment.html>
