[petsc-users] Possible causes for segmentation violation error at EPSSetOperators
Shitij Bhargava
shitij.cse at gmail.com
Tue Aug 14 08:10:30 CDT 2012
Thank you so much.
That fixed it.
On 14 August 2012 17:01, Jose E. Roman <jroman at dsic.upv.es> wrote:
> El 14/08/2012, a las 11:40, Shitij Bhargava escribió:
> > Hi all !
> > I am using fortran with petsc-3.2-p7, and slepc-3.2-p5
> > A code snippet of the place where the error is coming:
> > call EPSCreate(PETSC_COMM_WORLD,eps,ierr)
> > call EPSSetOperators(eps,AR,PETSC_NULL,ierr) <-------
> > call EPSSetProblemType(eps,EPS_HEP,ierr)
> > The error message:
> > [0]PETSC ERROR:
> > [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> probably memory access out of range
> > [0]PETSC ERROR: Try option -start_in_debugger or
> -on_error_attach_debugger
> > [0]PETSC ERROR: or see
> http://www.mcs.anl.gov/petsc/petsc-as/documentation/faq.html#valgrind[0]PETSCERROR: or try
> http://valgrind.org on GNU/linux and Apple Mac OS X to find memory
> corruption errors
> > [0]PETSC ERROR: likely location of problem given in stack below
> > [0]PETSC ERROR: --------------------- Stack Frames
> > [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not
> available,
> > [0]PETSC ERROR: INSTEAD the line number of the start of the
> function
> > [0]PETSC ERROR: is given.
> > [0]PETSC ERROR: [0] EPSSetOperators line 267 src/eps/interface/setup.c
> > [0]PETSC ERROR: --------------------- Error Message
> > [0]PETSC ERROR: Signal received!
> > [0]PETSC ERROR:
> > [0]PETSC ERROR: Petsc Release Version 3.2.0, Patch 7, Thu Mar 15
> 09:30:51 CDT 2012
> > [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> > [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> > [0]PETSC ERROR: See docs/index.html for manual pages.
> > [0]PETSC ERROR:
> > [0]PETSC ERROR: ./nmaex on a new-linux named shitij by shitij Tue Aug 14
> 14:39:24 2012
> > [0]PETSC ERROR: Libraries linked from
> /home/shitij/NMA/Lib/petsc-3.2-p7/new-linux12/lib
> > [0]PETSC ERROR: Configure run at Wed Jun 20 10:20:34 2012
> > [0]PETSC ERROR: Configure options
> --with-blas-lapack-dir=/opt/intel/Compiler/11.0/074/mkl/lib/em64t
> --with-mpi-dir=/home/shitij/NMA/Lib/mpich2-build
> > [0]PETSC ERROR:
> > [0]PETSC ERROR: User provided function() line 0 in unknown directory
> unknown file
> > application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
> > Now, my program conditionally branches in the beginning and then
> converges somewhere in the middle, after which this piece of code comes.
> One branch works fine, but the other doesn't. So the usage of the function
> itself is correct, but something in the other branch is wrong. I can
> understand this much.
> > What I do not understand is why the error is coming at EPSSetOperators,
> and how do I debug this problem?
> > I verified that the MPIAIJ array, AR, itself is not null with MatView,
> and I already created the EPS context as eps in the previous line, and the
> other arguments to the function are the same as in the other branch, so
> they cannot be the problem. The values inside the AR array might be
> incorrect, but they are there so this error should not come because of that
> as far as I can understand.
> > Any help will be appreciated.
> > Thank you in advance.
> Use PETSC_NULL_OBJECT as in the examples provided in SLEPc:
> call EPSSetOperators(eps,A,PETSC_NULL_OBJECT,ierr)
> Jose
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120814/ca0061e5/attachment.html>
