[petsc-users] Field split questions
Colin McAuliffe
cjm2176 at columbia.edu
Mon Aug 13 16:06:37 CDT 2012
> No, No, No. You do not have to write a DM implementation.
> You just have to define the data layout in a PetscSection and attach it to
> the DM with DMSetDefaultSection.
> Matt
Does use of the PetscSection mean that it is neccesary to define a
DMMesh? In other
words is there a way to create the data layout for the physics without
having to specify
any information about the mesh?
Thanks
Colin
Quoting Matthew Knepley <knepley at gmail.com>:
> On Thu, Aug 9, 2012 at 10:22 AM, Dmitry Karpeev <karpeev at mcs.anl.gov> wrote:
>> On Thu, Aug 9, 2012 at 10:02 AM, Colin McAuliffe
>> <cjm2176 at columbia.edu>wrote:
>>> Sanjay, thanks for the reply but I am avoiding using blocked format since
>>> my problem has 10 dofs per node but only has either dofs 1-3 or 4-10 active
>>> on a particular node. If I use block the equations I run out of memory
>>> pretty quickly on my machine but can get to reasonable sized problems with
>>> the unblocked format.
>>> Matt, sorry I am not getting this, but I am still not sure how the DM
>>> interface works. I can see in the function PCFieldSplitSetDefaults that
>>> there is an initial call to DMCreateFieldDecomposition and subsequent calls
>>> to DMCreateSubDM based on the command line options. What I am missing is
>>> how the first call to DMCreateFieldDecomposition is able to figure out
>>> which equations belong to which field just from command line info such as
>>> -pc_fieldsplit_0_fields 2,0. Where/how are the fields 2 and 0 defined?
>> This might change slightly in the near future in petsc-dev to allow one to
>> define splits using named fields.
>> In any event, there has to be DM support to implement the decompositions
>> over a particular mesh/problem over that mesh.
>> With DMDA you can essentially get combinations of strided fields in each
>> split. DMCOMPOSITE allows you
>> to pull out combinations of the subproblems that were put in there to
>> begin with. If you have your own mesh, you have to write
>> a DM implementation around it to expose the available fields.
> Matt
>> Dmitry.
>>> Thanks
>>> Colin
>>> On Thu, Aug 9, 2012 at 9:21 AM, Sanjay Govindjee <s_g at berkeley.edu>
>>>> wrote:
>>>> Colin,
>>>>> I you block the equations in FEAP, then the restrained BCs are
>>>>> 'included' in assembled PETSc matrix (these dofs have rows that are zero
>>>>> modulo a value of unity on the diagonal and the restrained value on the
>>>>> right-hand side).
>>>> However, this is not necessary with the DM interface.
>>>> Matt
>>>> -sg
>>>>> On 8/9/12 8:41 AM, Colin McAuliffe wrote:
>>>>> From what I can gather from the petsc-dev source it looks like the
>>>>>> commands in 4) will then generate the splits using strided blocks. The
>>>>>> problem with that is the fortran code I am using (FEAP) uses petsc to
>>>>>> assemble and solve the linear problem within its own nonlinear and time
>>>>>> stepping schemes. The linear problem that petsc solves already has
>>>>>> boundary
>>>>>> conditions applied to it so petsc only sees the active (unrestrained)
>>>>>> equations. So then in general fields can't be extracted from the active
>>>>>> equations using strided blocks and I am stuck with generating the index
>>>>>> sets defining the splits on my own. Will it still be possible to make
>>>>>> use
>>>>>> of the new DM functions in this case?
>>>>>> FEAP website:
>>>>>> http://www.ce.berkeley.edu/****projects/feap/<http://www.ce.berkeley.edu/**projects/feap/>
>>>>>> <http://www.ce.**berkeley.edu/projects/feap/<http://www.ce.berkeley.edu/projects/feap/>
>>>>>> Colin
>>>>>> On Wed, Aug 8, 2012 at 10:51 PM, Matthew Knepley <knepley at gmail.com>
>>>>>>> wrote:
>>>>>>> On Wed, Aug 8, 2012 at 10:23 PM, Colin McAuliffe <
>>>>>>>> >wrote:
>>>>>>>> Thanks all, regarding use of DM in 3.3, is the procedure now to
>>>>>>>> create
>>>>>>>>> the fields with PCFieldSplitSetIS and then use
>>>>>>>>> DMCreateFieldDecompositionDM
>>>>>>>>> to create a new DM based from the new fields and the DM for the
>>>>>>>>> original
>>>>>>>>> problem?
>>>>>>>>> 1) Use petsc-dev
>>>>>>>> 2) PCFieldSplitSetIS() is independent. This allows you to define
>>>>>>>> splits
>>>>>>>> however you want, but then recursive gets harder
>>>>>>>> 3) In 3.3., it uses DMCreateFieldDecompositionDM() to split all
>>>>>>>> fields
>>>>>>>> apart at once
>>>>>>>> 4) In petsc-dev, it uses DMCreateSubDM() which can split off any
>>>>>>>> combination of fields, which from the command line is something like
>>>>>>>> -pc_fieldsplit_0_fields 2,0 -pc_fieldsplit_1_fields 1,3
>>>>>>>> I should have shown recursive:
>>>>>>> -fieldsplit_0_pc_type fieldsplit
>>>>>>> will split 2,0 into two blocks.
>>>>>>> Matt
>>>>>>> Matt
>>>>>>>> Colin
>>>>>>>>> Colin McAuliffe
>>>>>>>>> PhD Candidate
>>>>>>>>> Columbia University
>>>>>>>>> Department of Civil Engineering and Engineering Mechanics
>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>> experiments is infinitely more interesting than any results to which
>>>>>>>> their
>>>>>>>> experiments lead.
>>>>>>>> -- Norbert Wiener
>>>>>>> their
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>>>>> Sanjay Govindjee, PhD, PE
>>>>> Professor of Civil Engineering
>>>>> Vice Chair for Academic Affairs
>>>>> 779 Davis Hall
>>>>> Structural Engineering, Mechanics and Materials
>>>>> University of California
>>>>> Berkeley, CA 94720-1710
>>>>> Voice: +1 510 642 6060
>>>>> FAX: +1 510 643 5264
>>>>> s_g at berkeley.edu
>>>>> http://www.ce.berkeley.edu/~****sanjay<http://www.ce.berkeley.edu/~**sanjay><
>>>>> http://www.ce.berkeley.edu/~**sanjay<http://www.ce.berkeley.edu/~sanjay>
>>>> their
>>>> experiments lead.
>>>> -- Norbert Wiener
>>> Colin McAuliffe
>>> PhD Candidate
>>> Columbia University
> experiments lead.
> -- Norbert Wiener
Colin McAuliffe
PhD Candidate
Columbia University
