[petsc-users] mat_view_draw resolution
Barry Smith
bsmith at mcs.anl.gov
Mon Aug 13 15:22:23 CDT 2012
From the manual page for PetscViewerDrawOpen() is -geometry <x,y,w,h> so give this a try.
Note also that you can create a PetscViewerDrawOpen() directly in your code setting the size in the code the way you like and pass this viewer to MatView().
Barry
On Aug 13, 2012, at 2:06 PM, "Ronald M. Caplan" <caplanr at predsci.com> wrote:
> Hi, Is there any way to set the output window size or resolution of mat_view_draw from the command line?
> - Ron
