[petsc-users] [Libmesh-users] Convergence rate for petsc virs
Ataollah Mesgarnejad amesga1 at tigers.lsu.edu
Mon Aug 13 10:14:48 CDT 2012
Dmitry,
On Aug 12, 2012, at 3:13 AM, Dmitry Karpeev <karpeev at mcs.anl.gov> wrote:
> On Sat, Aug 11, 2012 at 6:36 PM, Subramanya Gautam Sadasiva <ssadasiv at purdue.edu> wrote:
> Hi,
> I was trying the snes solver on the obstacle problem by modifying miscellaneous ex 7 and I get only linear convergence times.Is this what is expected from the virs solver?
> Yes, in the sense that you can't expect Newton's typical quadratic convergence: you are not using Newton's method in the usual sense,
> since the linear (and, in a sense, the nonlinear) problem you are solving changes every time the coincidence set changes.
You see this is really bad for a case like mine where essentially I am solving a quadratic problem with box constraints (Jac and Constraints are constant during each solve). Is there anything we can do to use this structure shouldn't we be able to get a quadratic convergence ?
Ata
> Dmitry.
> THanks,
> Subramanya
> Live Security Virtual Conference
> Exclusive live event will cover all the ways today's security and
> threat landscape has changed and how IT managers can respond. Discussions
> will include endpoint security, mobile security and the latest in malware
> threats. http://www.accelacomm.com/jaw/sfrnl04242012/114/50122263/
> Libmesh-users mailing list
> Libmesh-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/libmesh-users
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120813/15db578d/attachment.html>
